SCSI Error when ripping Certain Blu-rays
JimT1701
#1 Post by JimT1701 » Mon Nov 19, 2012 6:32 pm
I have been trying to Rip two different movies for some time and I keep getting the same error. The rip goes all the way to 100% and then stops with a SCSI error and the resulting MKV is deleted. Is this a copy protection error or is the disc damaged? All other discs rip fine except these two. I am running the most recent 1.7.9 version on a Windows 2008 R2 server with 16GB of RAM. Screenshots attached.
JimT1701
Re: SCSI Error when ripping Certain Blu-rays
#2 Post by JimT1701 » Mon Nov 19, 2012 7:11 pm
Well it looks like I should have read this forum a little more before posting this question. Seems this error could indicate a damaged disc. I can try using another drive I guess as the discs themselves are very clean I make sure all my discs are flawless. Any other suggestions are welcome.
setarip_old
#3 Post by setarip_old » Wed Nov 21, 2012 6:08 pm
Hi!
In light of you problem, you've nothing to lose by very carefully and thoroughly cleaning the discs once again. Some things are not visible to the naked eye, while others (light scratches, etc.) are not visible due to the angle of the light being used to check...
I've been (pleasantly) surprised more than once ;>}
cryp7
#4 Post by cryp7 » Tue Jan 22, 2013 5:48 am
Had this same error. The solution that I found was setting the Read Retry Count in the Preferences menu to 25. Once it hit the point that was causing issues, it took a little bit, but it managed to skip the corrupted or damaged sectors.
