Hi All,
Ive been using Makemkv for some time now, and am glad that it now supports DTSHD etc,
Previously i have been ripping my blurays with AnyDVDHD with the protection removed and the option to be compatible with powerdvd also checked. When i try to open these ISOs with makemkv i get the popup that warns about using anydvd at the same time (which i have now uninstalled but it still comes up) then i click yes, it will open the ISO but it will not show the main movie or any of the audio streams, ive tried this on a number of discs with the same result.
Is this a known bug?
Regards,
Brett
MakeMKV cant open ISOs created with ANYDVDHD
Re: MakeMKV cant open ISOs created with ANYDVDHD
it still should open it. can you please check "enable debug messages" in preferences, restart the app and post produced log file here or send it to support@makemkv.com . Thank you.
Brettv
No worries, heres what i get when i try to open the ugly truth
DEBUG: Code 0 at Y|q<d#]F(j4#]1e#&U*G:121262900
DEBUG: Code 117833938 at 8fRGc%plpJgwFvvE:29399864
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05004.m2ts' at offset '0'
DEBUG: Code 0 at iyYk*2Go6H%%dKe)cA_:121266925
DEBUG: Code 0 at 8fRGc%plpJgwFvvE:121265614
DEBUG: Code 117833938 at R=Y<hpp+Y2 Cc7+8=+:121262371
DEBUG: Code 117833938 at R=Y<hpp+Y2 Cc7+8=+:213132445
DEBUG: Code 117833938 at R=Y<hpp+Y2 Cc7+8=+:29393654
DEBUG: Code 0 at gVZtj^ti4tpvbU@C^I$t:213132376
DEBUG: Code 0 at Ko9yER9(:Mj6.\feN6;b:29393516
DEBUG: Code 0 at Ko9yER9(:Mj6.\feN6;b:213129639
DBG ASSERT: 0@r%`1E1nypdF^Lf E*2Vg>,K+=,yC7$O at ~#QLZoXJ#XjlXw6e_ l#xWUuD:121262026
DEBUG: Code 0 at Ko9yER9(:Mj6.\feN6;b:213130674
DEBUG: Code 0 at gVZtj^ti4tpvbU@C^I$t:213130053
DEBUG: Code 0 at Ko9yER9(:Mj6.\feN6;b:121262164
File 01027.mpls was added as title #5
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05005.m2ts' at offset '0'
File 01028.mpls was added as title #6
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05006.m2ts' at offset '0'
File 01029.mpls was added as title #7
LIBMKV_TRACE: No CC5 in 01044
LIBMKV_TRACE: No CC5 in 01045
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/00011.m2ts' at offset '0'
DEBUG: Code 117833938 at gVZtj^ti4tpvbU@C^I$t:213133365
DEBUG: Code 0 at =U@(b"Zp(.>\gj{fyna}:213131525
DEBUG: Code 29 at =U@(b"Zp(.>\gj{fyna}:29396805
Failed to decode audio/video data for title #8 - invalid mux or internal error, title skipped.
DEBUG: Code 0 at iyYk*2Go6H%%dKe)cA_:121269064
Title #00002.mpls was skipped
LIBMKV_TRACE: No CC5 in 01006
LIBMKV_TRACE: No CC5 in 01007
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
File 00000.m2ts was added as title #8
Failed to decode audio/video data for title #9 - invalid mux or internal error, title skipped.
Title #00011.m2ts was skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #00104.m2ts has length of 9 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title #05000.m2ts has length of 1 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05001.m2ts' at offset '0'
File 05001.m2ts was added as title #9
Title #05007.m2ts has length of 7 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05009.m2ts' at offset '0'
File 05009.m2ts was added as title #10
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05010.m2ts' at offset '0'
File 05010.m2ts was added as title #11
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05011.m2ts' at offset '0'
File 05011.m2ts was added as title #12
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05012.m2ts' at offset '0'
File 05012.m2ts was added as title #13
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05013.m2ts' at offset '0'
File 05013.m2ts was added as title #14
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05014.m2ts' at offset '0'
DEBUG: Code 0 at 0|1N<z1UJBAnI\MwrZpB4:121264326
File 05014.m2ts was added as title #15
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05015.m2ts' at offset '0'
File 05015.m2ts was added as title #16
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05016.m2ts' at offset '0'
File 05016.m2ts was added as title #17
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05017.m2ts' at offset '0'
File 05017.m2ts was added as title #18
Error 'Internal error - Decryption error (210)' occured while reading '/BDMV/STREAM/05018.m2ts' at offset '0'
File 05018.m2ts was added as title #19
Operation sucessfully completed
it looks like an incorrect rip. was it created with a really old version of anydvd?
Brettv
Well thats the thing, on all ISOs it does the same thing, up until a week ok using some of the latest versions of anydvdhd, they also play fine in powerdvd.
setarip_old
@Bretty
HI!
Ever so slightly offtopic but, why are you bothering to first rip you original BluRau disc to an .ISO image file - and then using MakeMKV with the .ISO image file?
Why don't you just let MakeMKV rip your original BluRay disc to an .MKV file?
HI!
Brettv
Hi well, as of right now, i wont be doing that anymore with the new release that supports master audio, but before the release i used anydvdhd to preserve the audio.setarip_old wrote:@Bretty
HI!
cheers
Brett
Marc_G
@Setarip_Old:
You asked why ripping a BD to iso... here's my perspective. Most of the content I watch comes from rental discs that I rip, watch, then delete to make room for the next disc. I want to turn those discs around quickly, so the first thing I do when I get the disc is to rip it to Iso with AnyDVDHD. The physical disc then goes back where it came from. Sometime before I want to watch the movie (or episodes of a TV series) I'll use MakeMKV on the ISO to pull the movie/episodes out. I usually mount the iso in Virtual Clone Drive as I've had limited success with MakeMKV reading directly the ISO. I extract the MKV I want, watch it, then delete the MKV and ISO.
So, why keep an ISO instead of just ripping out the MKV? I've had cases where I wanted to watch some special content or whatever on the bluray, an alternate ending, or in rare cases something was wrong with the MKV rip or didn't have a good codec and I needed the original iso to play in PowerDVD. For example, MakeMKV did a great job of pulling out episodes of Torchwood seaon 3 from the bluray, but when I went to play them they turned out to be 1080i VC1 video which is nearly impossible to play with typical windows Codecs, or MPCHC, or any of the usual suspects. It was a lot easier just to use PowerDVD to play the iso in this case. That's why I always keep the ISO until I'm done with the content. I hate watching content via PowerDVD because of all the menus/FBI warnings/etc.. But it's handy for those cases where I need it.
I have had no compatibility issues between PowerDVD and MakeMKV yet, and have not yet updated to 1.4.10 .. I hope I won't start to see compatibility issues. That would bite.
Hope this helps in understanding the need to rip iso's even while MakeMKV does a great job.
Marc
Marc
Brettv
That was similar to the procedure i was using, i was ripping to an ISO to turn the disc around quickly. Then work on it (with makemkv) later.
However, with the new release i will be using makemkv and thats it.
I have also tried opening the disc while the ISO has been mounted with Daemon tools, and it still does not seem to work. I will try virtual clone drive as mentioned above and see if that makes any difference.
Cheers,
Brett
Cheers,
Brett
Brettv
Hi All,
Just posting to say that the latest release fixes my above, issue,
Thanks Team!
Thanks Team!
