larionlarion
#1
Post
by larionlarion » Thu Nov 15, 2012 12:15 pm
I am trying to rip CSI S11, the problem is that MakeMKV does not detect episodes, I get one title of 28 GB and one title of 6 GB i guess that is one of the episodes.
Am i doing something wrong?
This happens to alot of CSI Blu-Ray's not only season 11.
Attaching the log even though there is not much info there :
Debug log started at Thu Nov 15 12:04:40 2012 , written by MakeMKV v1.7.9 win(x64-release)
001005:0000 MakeMKV v1.7.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQEEAQEEAQ==
DCE=BG45VWKPxS2e9MgQCT9ltq7j3Bx86Ud5xCebXZAW7vc464e1/nyC9JCl3HKmH+E7EA70KqbfSPyTtpPwU24eT9gqJvd2ZXCx58b4R8cVX4UiF8WR57PwkYvUbAnwz4k4gcZ/awoO3R823pLDsDcIj6afLEjJ6BmCfA==
DISCID=8939E1252677CC1437A53D45CC8077085D08F77C
003307:0000 File 01000.mpls was added as title #0
003307:0000 File 00004.m2ts was added as title #1
003307:0000 File 00005.m2ts was added as title #2
003307:0000 File 00006.m2ts was added as title #3
003025:0000 Title #00007.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #4
Application exited at Thu Nov 15 12:05:24 2012
setarip_old
#2
Post
by setarip_old » Thu Nov 15, 2012 4:43 pm
Hi!
Sounds like a disc that contains a menu that includes "Select All" as well as "Select individual episodes" - structured in such a way that MakeMKV misinterprets the contents...
larionlarion
#3
Post
by larionlarion » Thu Nov 15, 2012 7:16 pm
Ok, is there something I can do to fix this?
Or am i screwed?
I know I can use other programs, but I like using MakeMKV whenever possible.
setarip_old
#4
Post
by setarip_old » Thu Nov 15, 2012 8:02 pm
I'm fairly certain this problem has come up previously - and, if so, "mike admin" will likely address it shortly (He's good that way ;>})...
Post
by mike admin » Sat Nov 17, 2012 6:43 am
That's probably the way the disc is authored. When you select a title in a title tree, on the right pane you'll see an item called "segment map". That's a list of M2TS files that are part of the title. I won't be surprised that you have one gigantic "play all" title. If this is the case, the workaround exist but is a bit ugly:
- Make a (decrypted) full disc backup with MakeMKV
- Open backup with MakeMKV, and write down the names of M2TS files for each episode.
- Close MakeMKV, go to the folder with backup, navigate to PLAYLIST directory and delete all MPLS files.
- Launch MakeMKV again, open backup - you'll see a lot of small titles. On the right pane for each title you'll see M2TS nae in "source name". Select the titles you need and you're done.
