I cannot use MakeMKV due to AnyDVD HD?
GFOviedo
Post by GFOviedo »
I have disabled and turned off AnyDVD HD, but I still get the warning saying that AnyDVD HD still enable. What's up with this?
Romansh
Re: I cannot use MakeMKV due to AnyDVD HD?
Post by Romansh »
You must be running MakeMKV on a disc image or folder that was ripped with AnyDVD.
bw001
Post by bw001 »
I've successfully processed many discs with MakeMKV after decrypting with AnyDVD HD. Just answer "Yes" to the prompt.
setarip_old
Post by setarip_old »
Everything will be fine (despite the information note), as long as you don't have AnyDVD either active or "gray" ("Enabled"?)
GFOviedo
Post by GFOviedo »
I was able to rip the movie with MakeMKV by using the folder structure option rather than the ISO option. I've use the ISO option before and never had that prompt. The only issue I've got not is that the movie drops the sound and brings it back within less than a second, which is something that I've had happened before with BD MKV files. For some reason or another, I can't rip the BD Brave with ClownBD.
