I get no sound when I ripped these two Criterion blu rays, "12 Angry Men" and "The 39 Steps" (for the latter, I only got the sound on the audio commentary but none on the two films). I've ripped other blu rays and had no problems with the sound. Is it a "Criterion-related" problem? Is the fact that Criterion blu rays are "Region A" a problem?
Thanks a lot for your help
My system:
Mac OS X 10.7.5
3.06 GHz Intel Core i3
4GB 1333 MHz RAM
I use VLC to play the ripped blu rays
No sound when ripping Criterion blu rays
starwanderer
starwanderer
Re: No sound when ripping Criterion blu rays
Nobody? I guess this problem with Criterion blu rays can't be an isolated problem, can it? ; )
crowfax
Can you post the info for the file that you're having issues with us if mediainfo please.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
starwanderer
Thanks. I'm having problems with blu rays with mono LPCM sound.crowfax wrote:Can you post the info for the file that you're having issues with us if mediainfo please.
VLC reports this message: "cannot open codec (PCM S24 LE)"
Here's the media info for "12 Angry Men"
File: /Volumes/Music/Films/12_ANGRY_MEN_t00.mkv
Format: Matroska/WebM file format
Chapters count: 18
Stream count: 3
Duration: 01:36:21
Bit rate: 25157 kb/s
Meta info:
title: 12 ANGRY MEN
creation_time: 2012-11-13 22:29:45
Stream 0
Type: video
Codec: h264
Codec profile: High
Width: 1920
Height: 1080
Sample aspect ratio: 1:1
Display aspect ratio: 16:9
Pixel format: yuv420p
Frame rate: 23.98 fps
Meta info:
language: eng
Stream 1
Type: audio
Codec: pcm_s24le
Bit rate: 1152 kb/s
Sample rate: 48000 Hz
Sample format: s32
Channel: 1
Default: YES
Meta info:
title: 1/0
language: eng
Stream 2
Type: subtitle
Codec: pgssub
Default: YES
Meta info:
language: eng
and this is for another Criterion blu ray: "Brief Encounter," which surprisingly has been ripped right!
I've highlighted in bold where I think the problem lies.
File: /Volumes/Music/Films/Brief Encounter_1.mkv
Chapters count: 9
Stream count: 4
Duration: 01:26:47
Bit rate: 39882 kb/s
Meta info:
creation_time: 2012-11-14 22:01:31
Stream 0
Type: video
Codec: h264
Codec profile: High
Width: 1920
Height: 1080
Frame rate: 24.40 fps
Default: YES
Meta info:
language: eng
Stream 1
Type: audio
Codec: pcm_s16le
Bit rate: 4608 kb/s
Sample format: s16
Channel: 6
Default: YES
Meta info:
language: eng
Stream 2
Type: audio
Codec: ac3
Bit rate: 192 kb/s
Sample format: s16
Channel: 1
Default: YES
Meta info:
language: eng
Stream 3
Type: subtitle
Codec: pgssub
Default: YES
Meta info:
language: eng
crowfax
This is a vlc issue. Best to raise it with them.
You can also rip with the FLAC profile in makemkv which so far as I know will convert LPCM to FLAC which will work in VLC
starwanderer
Thanks. I'll try that. Anyway, I'm not sure if it's only a VLC issue. I also have another Mac blu ray player and no sound either.crowfax wrote:This is a vlc issue. Best to raise it with them.
Wondercow
I have 12 Angry Men and it ripped without issue. As Crowfax mentioned, VLC doesn't handle the LPCM codec used on Criterion releases, so those soundtracks need to be converted to another format. I recommend FLAC since it saves a lot of space and keeps the audio lossless.
starwanderer
Thanks. One Criterion film that ripped with no issues is "Brief Encounter." I'll try ripping with the FLAC profile. Anyway, do you know if those Criterion blu rays will play on a TV? I still have no cable to connect my iMac to the TV and it would be great if I don't have to re-rip them againWondercow wrote:I have 12 Angry Men and it ripped without issue. As Crowfax mentioned, VLC doesn't handle the LPCM codec used on Criterion releases, so those soundtracks need to be converted to another format. I recommend FLAC since it saves a lot of space and keeps the audio lossless.
telletran1@juno.com
Sorry if this has been answered in another thread, but I am having the same problem as OP. Anytime I rip a Criterion title, I do not get sound. The 3 titles i have tried are The Lady Vanishes, Yojimbo and Rashomon. I saw in one of the responses that you could switch the profile to a FLAC profile and that should resolve. However, I don't seem to be able to accomplish switching to the FLAC profile.
Your assistance is appreciated.
