Trying to rip disc 1 of the 4 disc DVD set "Chuck Berry - Hail, Hail Rock N Roll" and I'm getting the following error. It only appears to see the smaller two titles and misses the main feature completely. Any tips would be appreciated. I've been ripping my entire collection for a PLEX media server and this is the first time I've run into this issue. Running MakeMKV 1.7.71 on Mac 10.8.2. Log and IFO files attached in the Zip.
EDIT: Just tried 1.7.79 version and got the same error
Debug log started at Sun Nov 11 22:32:45 2012 , written by MakeMKV v1.7.71 darwin(x86-release)
001005:0000 MakeMKV v1.7.71 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/healy/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HC10" opened in DASPI v1.3 mode.
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #0 was added (1 cell(s), 0:03:57)
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
Title skip vts=1 pgcn=1 hash=A6053E21C9871A62
Title skip vts=2 pgcn=1 hash=10055D8F0FA186CE
003025:0000 Title #2 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #3 was added (1 cell(s), 0:02:51)
Title skip vts=4 pgcn=1 hash=733167DAE6C3B251
Application exited at Sun Nov 11 22:40:04 2012
structure protection error on Hail Hail Rock N Roll
nwgeek
- HailHailRnR.zip
- Log file and IFO files from the DVD
- (60.55 KiB) Downloaded 595 times
setarip_old
Re: structure protection error on Hail Hail Rock N Roll
Hi!
Does the original Disc 1 play properly on your computer?
nwgeek
Yes, it plays perfectly fine in two different computers. Tried ripping it on both of them (Both Mac's). Am going to try ripping it on a Windows 7 PC next.
nwgeek
Same exact error on two different PC's that I tried.
nwgeek
Ended up ripping it in another program and got an MKV that way. First disc in over 400 that I've ripped that has been a problem.
setarip_old
I'm fairly sure Mike will look into this, as it appears, at first blush, to use a new protection scheme...
