I am not been able to find any setting, which would let me control downloading of .svq file.
Prometeus crash
atomic7431
Re: Prometeus crash
I have ripped this today without issues so thanks
using latest version 1.79.
only option i can think of as a new user is under general tab `allow contacting web server for updates`
setarip_old
Re: Prometeus crash
That's correct...only option i can think of as a new user is under general tab `allow contacting web server for updates`
Re: Prometeus crash
Yes, that option is checked in the settings. I have sent the dump to svq@makemkv.com email address. I am hoping someone would check/respond!
Re: Prometeus crash
Thank you so much, looks like it has all the support files it needs to rip the disc. You guys are awesome!
setarip_old
Re: Prometeus crash
You're quite welcome. Glad to hear that things worked out for you ;>}
Re: Prometeus crash
The 4-disc version of this film won't rip for me using 1.7.9. I get the same BD+ errors as the others listed here. I only want to rip the BR and not the 3D version.
Any ideas?
Edit: AH! Nevermind...I figured out the SVQ file placement thingy...it's ripping now. If there's a problem with it I'll report back. Cheers.
Any ideas?
Re: Prometeus crash
Hi
Iam using MakeMKV on a win7 64bit, v.1.7.10 and Iam trying to make 3D mvk file
from the Prometheus 3D disk,I can copy files to my harddrive no problem there,
but when I try to make 3D MKV file it almost finishes and ends up with "MakeMKW (not responding)"
I mark the Video box with: Mpeg4-MVC-3D, audio box: DD3/2+1 English and skip subtitles.
MakeMKW ends up with (not responding) every time with less than a minute left of saving the MKV file.
Is there any solution to this problem ?
- Untitled.png (102.44 KiB) Viewed 15519 times
