Hi all -
trying to back up this blurry and also convert the audio to FLAC. It's erroring out at the very end:
Saving 1 titles into directory XXXXX using profile 'FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/flac.mmcp.xml'
DEBUG: Code 57 at /\@G<qo+C,#,p2ggJ{:121262095
DEBUG: Code 1 at g!f'}pUW1{P|X&(G:29395655
DEBUG: Code 0 at ]Y5QISs'tO,N'ewXDkLN:29393332
DEBUG: Code 0 at 4/Ao^-@z4I2ta6L#f6H"L:29398300
anyone else have a similar issue? this is with latest 1.7.8 version. 1.7.7 had same issue.
Rush Snakes and Arrows won't rip
- Contact:
Re: Rush Snakes and Arrows won't rip
This was fixed in 1.7.8 . Are you sure that you're using the mmffmpeg executable that comes with MakeMKV? Is "ffmpeg location" empty in advanced preferences?
Yep - just checked: ffmpeg location is blank (note that I did download and build ffmpeg on my mac, but the location is confirmed blank in makemkv)
- Contact:
Were you ever able to save dts-hd track as flac from any blu-ray? Are you sure that the error is specific to this disc?
Yes -- over 100 times now without issue (and thanks by the way for that feature! It's what us MAC folks need to do if we want no loss in audio quality)
Just this disc has caused issues so far.
