Profile parsing error: multiple default profiles found
Chetwood
#1 Post by Chetwood » Tue Nov 06, 2012 7:49 am
Profile parsing error: multiple default profiles found, rename your custom profile
is what I get when I start makeMKV 1.7.8/7.9. MakeMKV dir contains
default.mmcp.xml
flac.mmcp.xml
wdtv.mmcp.xml
the last of which is what I've selected under Advanced. c:\Users\Chetwood\.MakeMKV dir is empty. MakeMKV data directory is
D:\Programme\MakeMKV. So what's the problem?
Re: Profile parsing error: multiple default profiles found
#2 Post by mike admin » Wed Nov 07, 2012 8:55 am
There should be a "rogue" profile in MakeMKV data directory that is named "default" ( :number ) internally. MakeMKV skips these files. Unfortunately it doesn't print the file name so there is no way to tell what profile is offending. As profile was skipped, the only downside is this error message.
Chetwood
#3 Post by Chetwood » Thu Nov 08, 2012 6:13 am
Right, it looks like this:
default.mmcp.xml
<name lang="mogz">:5086</name>
flac.mmcp.xml
<name lang="eng">FLAC</name>
wdtv.mmcp.xml
<name lang="eng">WDTV</name>
I just don't get why MakeMKV is complaining since it's installing/naming these files itself when doing a new install.
BTW, Mike, would be nice of you to check your PMs and to upgrade the forum so it's getting harder for these annoying spammers. Thanks.
Multikrabbe
#4 Post by Multikrabbe » Thu Oct 16, 2014 11:57 am
Hi All
please let me reanimate this thread because, since several versions of MakeMKV, i have this same issue.
Meanwhile I scanned my complete PC and even the registry but cannot find multiple occurances of the XML files.
Unfortunately I always have this annoying "multiple default profiles found, rename your custom profile" message.
BTW: it's the licenced program version.
Do you have any hints or tips how to solve this issue?
All XLM files looks good, no double content inside.
Before installing the latest version 1.8.13 I deleted the install folder but still the same.
Best regards
Joerg
