"AACS host certificate is revoked by your drive" Issue
Re: "AACS host certificate is revoked by your drive" Issue
Post by Woodstock » Mon Oct 22, 2012 2:43 am
I would guess that the drive is taking up too much current. I've seen this behavior before with a printer; adding a POWERED USB hub between the drive and the computer will probably fix it.
Sportzter
Post by Sportzter » Mon Nov 05, 2012 9:46 am
So I also have this error "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" - I have read as many posts here on MakeMKV that I can, but i have a couple of questions left.
Any BluRay that i put in this drive, gives me this error (I was able to play the Star Wars BDs about a month ago but not now) - from newer BD that were released recently or some that were a couple of years ago. I cannot get any movie to play/rip.
1. Is the BD reader now unusable for Blu-rays?, ie. should I just throw this drive away and start fresh or is the problem embedded in software somewhere?
2. I have tried to do the AACS folder but I don't know what this means in the FAQ: First, you need to set an "AACS keys directory" in preferences (I don't see where this is available in preferences); then you need to put a keyfile with disc for your key into this directory. (Do we have to create the directory? Is this directory in the Users\.makemkv directory? Is there a specific name that we need to call this directory?)
3. Will All BluRay Drives eventually succumb to the "Key revocation" problem - or how do we prevent this from happening in the future? What specific drive/models are "resistant" to the "Key Revocation" problem, if their are any that will not have that problem.
I appreciate any and all feedback.
Sportzter
Here is my current drive info.
Manufacturer: ASUS
Product: BW-12B1ST
Revision: 1.02
Serial number: B6D0CL251129
Naiera
Post by Naiera » Tue Apr 01, 2014 2:29 pm
Woodstock wrote:I would guess that the drive is taking up too much current. I've seen this behavior before with a printer; adding a POWERED USB hub between the drive and the computer will probably fix it.
This did not make my problem go away.
Post by mike admin » Thu Apr 03, 2014 7:51 am
Sportzter wrote:So I also have this error "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
What is the "highest MKB version" that is displayed right after that error?
