Can I Change the Number of Reference Frames?
Bob K
Post by Bob K »
MakeMKV rips some of my bluray disks with Reference Frames=2, such as Source Code, Jumper, and Salt. Others, like Snow White and the Huntsman and Toy Story 3 rip with Reference Frames=4.
My LG BD670 player will not cleanly play the files where Reference Frames=2. I get colored blocking and glitches throughout the film. I need Ref Frames of at least 3 in order for the video to play properly. I see the work TexasGrillChef has done in discovering this issue with LG players (http://www.makemkv.com/forum2/viewtopic ... 93&start=0); however, I don't yet see a native solution.
I re-encode with Handbrake as a workaround but would prefer to stick with MakeMKV.
Why does MakeMKV rip movies with different Reference Frame settings? And, is there a way for me to force MakeMKV to use a particular Reference Frame setting?
Chetwood
Re: Can I Change the Number of Reference Frames?
Post by Chetwood »
It doesn't.
Romansh
Post by Romansh »
Bob K wrote:Why does MakeMKV rip movies with different Reference Frame settings?
Because the studio encoded the Blu-ray with 2 refs, that's all.
The easy workaround is to get a non-useless playback device, rather than sticking with the LG.
Bob K
Post by Bob K »
Great! Thanks for the feedback.
setarip_old
Post by setarip_old »
Hi!
There have been many posts, at this forum and others, indicating that the LG playback devices are, in general, problematic.
I concur with the suggestion made by Romansh:
Chetwood
Post by Chetwood »
Non-useless, LOL.
