Alienware 17x
MakeMKV v1.7.8 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00604.m2ts' at offset '977117184'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '134387712'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '30142464'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '37140480'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '9234432'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '110045184'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '128157696'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '113694720'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '124895232'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '28299264'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '47093760'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '6144'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '12288'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '18432'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '24576'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '30720'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '36864'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '43008'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '49152'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00622.m2ts' at offset '55296'
Downloading latest SVQ(s) to C:\Users\Bill/.MakeMKV ...
Loaded 140 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from 00000030.svq
BD+ code processed, got 1 FUT(s) for 29 clip(s)
Title #00201.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00801.mpls was added as title #0
Title 00851.mpls is equal to title 00801.mpls and was skipped
File 00850.mpls was added as title #1
Title 00800.mpls is equal to title 00850.mpls and was skipped
Title #00420.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00422.mpls was added as title #2
Title #00071.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00500.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00201.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00400.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00401.m2ts was added as title #3
Title #00331.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00350.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00330.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00332.m2ts was added as title #4
Title #00351.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00403.m2ts was added as title #5
Title #00404.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00405.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00406.m2ts was added as title #6
Title #00407.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00409.m2ts was added as title #7
Title #00410.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00411.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00408.m2ts was added as title #8
File 00601.m2ts was added as title #9
File 00603.m2ts was added as title #10
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00605.m2ts' at offset '0'
Title #00605.m2ts was skipped
Title #00607.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00609.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00611.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00613.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00615.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00617.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00618.m2ts was added as title #11
Saving 2 titles into directory H:/Video/Chronicle
Failed to save title 0 to file H:/Video/Chronicle/Chronicle_t00.mkv
Failed to save title 1 to file H:/Video/Chronicle/Chronicle_t01.mkv
0 titles saved, 2 failed
Chronicle [Blu-Ray] fails to process
Re: Chronicle [Blu-Ray] fails to process
Means your drive tried to get to a part of the drive, and couldn't find it. Either it didn't actually move to where it thought it did (problem with the drive itself), or, when it got there, it couldn't find what should have been there (problem with the disk).MEDIUM ERROR:NO SEEK COMPLETE
Have you cleaned the disk and the drive recently?
setarip_old
Hi!
If cleaning the disc and the drive doesn't fix things, exchange the disc for a new one at the place of purchase
N8QQW
The PC is pretty new, and the disc looks good, but I will try both suggestions. Thanks.
setarip_old
Let us know how it goes ;>}
