The Raid Redemption US Blu Ray
ncarusojr
Does anyone know which playlist is the right one for the US. It comes up with 4 that are the correct time. Thanks in advance..
setarip_old
Re: The Raid Redemption US Blu Ray
Hi!
I'd sincerely suggest that with only 4 possibilities, you should simply try each of them to see which (one or more of the four) is/are correct...
Smithcraft
Or you could look it up at the AVS forum BDInfo thread.
SC
SC
Cavalicious
Never knew that thread exist. Thanks for the heads-up!Smithcraft wrote:Or you could look it up at the AVS forum BDInfo thread.
SC
tobunk
did you ever figure it out? I assume it's the 800 playlist.
mustardsalad
It's the 800 playlist.
https://www.avsforum.com/threads/new-un ... d.1155731/
So just hit Ctrl+F on "Raid: Redemption" and you come to the entry, and copy and paste the url http://www.avsforum.com/t/1155731/new-u ... t_22495921 and it'll take you to that post and correct playlist number, right?
Wrong. Those urls aren't valid anymore - you paste in that url and the website simply re-directs you to the main page of the thread at https://www.avsforum.com/threads/new-un ... d.1155731/
So...... the only other information I had to go off of, other than scanning the entire 256-page thread manually, is that the post in that thread title is the 22,495,921st post. So I had to do a divide and conquer by narrowing down which subset of chunks of 50 pages got me closer and closer to that post number, and I finally found it at the top of page 229.
From there, I found the url for the Raid: Redemption post, and as of 2020, this url is the one that'll actually take you there: https://www.avsforum.com/threads/new-un ... t-22495921
This is why I much prefer having this information on makemkv instead - I've used this forum a lot in the past for playlist information, and it was frustrating seeing someone made a thread for this over 8 years ago and there still wasn't a definitive answer in the thread. So there you go - 00800.mpls is the correct playlist.
Jesus fuck, gentlemen...
THAT..........was a pain in the ass to look up. After some googling, I found the AVS Forum you're talking about:Smithcraft wrote: Sat Nov 03, 2012 4:41 am Or you could look it up at the AVS forum BDInfo thread.
SC
nitsuJcixelsyD
5 years later.. thank you for this. Was just trying to find what play list is the correct one and instead of having to do all the legwork from old broken forums, its right here in one place. Appreciate it.mustardsalad wrote: Thu Nov 19, 2020 12:56 am ...
