DTS-HD MA to FLAC conversion fails
stordoff
Post by stordoff »
Pretty much as the title states. I'm trying to convert a Blu-Ray to MKV, but I can't get the FLAC profile to work - I've set up dlldecoderdll.dll up in preferences (I've tried both the TMT5 dll and a version from elsewhere). Log below:
MakeMKV v1.7.8 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Stephen Tordoff/MakeMKV_log.txt
Loaded 136 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
File 00500.mpls was added as title #0
File 00720.mpls was added as title #1
Title 00850.mpls is equal to title 00500.mpls and was skipped
File 00020.mpls was added as title #2
File 00400.mpls was added as title #3
File 00310.mpls was added as title #4
Title 00801.mpls is equal to title 00500.mpls and was skipped
Title 00851.mpls is equal to title 00500.mpls and was skipped
File 00352.mpls was added as title #5
Title 00800.mpls is equal to title 00500.mpls and was skipped
File 00261.mpls was added as title #6
File 00011.m2ts was added as title #7
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 20 seconds and was therefore skipped
File 00804.m2ts was added as title #8
File 00825.m2ts was added as title #9
File 00835.m2ts was added as title #10
File 00836.m2ts was added as title #11
File 00837.m2ts was added as title #12
File 00838.m2ts was added as title #13
Saving 1 titles into directory C:/Video/BD using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
DEBUG: Code 50 at {T0*F4+BF%L =}Y):213132330
DEBUG: Code 0 at dm]9BM8zWH\GrgF19-+:121264211
DEBUG: Code 0 at dm]9BM8zWH\GrgF19-+:213134239
DEBUG: Code 0 at )-A~3X=9:MPjE,%8SPp+:213129984
DEBUG: Code 0 at vUaD%IhGz<DMAibVESS~Z:121262808
LIBMKV_TRACE: Exception: UpdateTrackInfo failed
Failed to save title 0 to file C:/Video/BD/W_t00.mkv
0 titles saved, 1 failed
Re: DTS-HD MA to FLAC conversion fails
Post by mike admin »
Please try 1.7.9 - it should work provided you're using mmffmpeg.exe that comes with MakeMKV ("ffmpeg location" is empty in advanced preferences)
stordoff
Post by stordoff »
1.7.9 seems to be working fine. Thanks.
