Buster Keaton The General
My PC seems unable to load this Blu-Ray.  Is there a known problem here?
				setarip_old
Re: Buster Keaton The General
Hi!
As a starting point, does the disc play in a standalone player?
Sorry to say I do not have a stand alone Blu-Ray player.  Only an LG USB Blu-Ray Reader.
				setarip_old
 (Trying to eliminate possible causes) Are you able to play other Blu-ray discs on your LG USB Blu-Ray Reader?
Have you had this problem with other Blu-ray discs?
Is this a new or used Blu-ray disc?
Is it a commercial, pressed Blu-ray disc or "something else"?
1 Yes. Just finished ripping the French film "Three Colors - White" from Blu-Raysetarip_old wrote: (Trying to eliminate possible causes) Are you able to play other Blu-ray discs on your LG USB Blu-Ray Reader?
2 Yes. Always commercial. About two times before. I forget the titles.
3 Used
4 Commercial
I... uhm... got a replacement for this disk from my source and both exhibited the same failure. I did not bother with the other failures
I've had success with about 25 Blu-Rays.
The Blu-Ray was pressed by "Kino Lorber" http://www.kinolorber.com and looks to be in very good shape. No visible scratches or blemishes.
				setarip_old
EPossibly either bad mastering (usually a batch of such discs), or your drive is beginning to fail or the drive may benefit from cleaning with a cleaning disc. Maxell makes one that sells for about $10US...
Thanks for the help.setarip_old wrote:EPossibly either bad mastering (usually a batch of such discs), or your drive is beginning to fail or the drive may benefit from cleaning with a cleaning disc. Maxell makes one that sells for about $10US...
				setarip_old
 You're quite welcome ;>}
