Terminator Salvation issues
The disk will read fine, but after selecting the title, tracks, output folder, and click make MKV, it produces a 122MB file in about 10 seconds and says complete. The file will play the first 10 seconds of the title. Whats the issue here?? I have tried all different combinations of titles and tracks and cannot get it to write the entire title.
noob,
Comporder1
noob,
Comporder1
Re: Terminator Salvation issues
Hi!
1) Are you referring to a standard DVD or a BluRay disc?
2) What is the region of your original disc?
errr.... Sorry
It is a Blu-ray disc, region 1 (I'm in USA)
Are you SURE you selected the primary movie title for creating the MKV? (It should be the largest, likely greater than 10GB and comprised of more than 10 Chapters)
Like I said, I tried all different combinations of titles and tracks. The disc shows two large titles; both are around ~26gb, one has 10 chapters, the other has 27. Both produce a file about 122mb (10 seconds long). When making the mkv, the "source" size says ~26gb. Everything seems right. Since this post, i have ripped two other blurays so I know my hardware is working.
I ripped terminator salvation a week ago and had no problems. It was using to old firmware???
Are you saying it might be the drive firmware too old? I just checked, it is the latest. Also, latested MakeMKV. Any other ideas?
Here are some screenshots. May this will give a little more in-site.
I meant to say I was using the old version of makemkv. I'm sure this doesnt matter. It's very strange.
Ideas anyone??!!
Since I and others have had no such problem when processing the R1 version of this BluRay disc, I'd suggest you:
1) Re-process your original BluRay disc with MakeMKV.
If you again have the same problem,
2) Return your original BluRay disc to the place of purchase in exchange for a new replacement.
I can confirm I had the same exact problem with Terminator Salvation Blu Ray. Ended up throwing into Clown_BD and then using MKVMerge, worked perfectly. Not an issue with the disc.
Cheers,
Damian
blog - http://dbone1026.blogspot.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Damian
thanks for the confirmation dbone1026. It's good to know it's not me or my hardware. I'll give your process a try.dbone1026 wrote:I can confirm I had the same exact problem with Terminator Salvation Blu Ray. Ended up throwing into Clown_BD and then using MKVMerge, worked perfectly. Not an issue with the disc.
Comporder1
