Just tried to copy the 3D video with MVC, but there is no check block option under video for MVC on this video. Yes, disk is 3D and there is an SSIF directory in STREAM with 3 files in it. The non-3D version copies OK as shown in logfile attached. Mediainfo confirms lack of 3D content in copied file.
I am currently using the linux x64 1.7.7 version because I have glibc erros with the 1.7.8 version as discussed in another place on the forum.
I have successfully gotten 3D video from another title (Journey to the Center of the Earth). How can I get the MVC 3D video check box to appear for Avatar?
Avatar Limited Edition 3D
Grouchy Penguin
- MakeMKV_log.txt
- (23.12 KiB) Downloaded 1096 times
- Contact:
Re: Avatar Limited Edition 3D
Bad luck for you - this bug was fixed in 1.7.8 . You'll have to wait couple days for 1.7.9 or you can boot from ubuntu 12 live cd.
Grouchy Penguin
Thanks for the update Mike. I am happy to hear the problem is already fixed. Since you say 1.7.9 will be out soon, I will wait for it.
