Terminator Salvation issues
comporder1
#1 Post by comporder1 » Wed Dec 30, 2009 9:11 pm
The disk will read fine, but after selecting the title, tracks, output folder, and click make MKV, it produces a 122MB file in about 10 seconds and says complete. The file will play the first 10 seconds of the title. :shock: Whats the issue here?? I have tried all different combinations of titles and tracks and cannot get it to write the entire title.
noob,
Comporder1
setarip_old
Re: Terminator Salvation issues
#2 Post by setarip_old » Wed Dec 30, 2009 11:44 pm
Hi!
1) Are you referring to a standard DVD or a BluRay disc?
2) What is the region of your original disc?
comporder1
#3 Post by comporder1 » Wed Dec 30, 2009 11:55 pm
errr.... Sorry :oops:
It is a Blu-ray disc, region 1 (I'm in USA)
setarip_old
#4 Post by setarip_old » Thu Dec 31, 2009 12:20 am
Are you SURE you selected the primary movie title for creating the MKV? (It should be the largest, likely greater than 10GB and comprised of more than 10 Chapters)
comporder1
#5 Post by comporder1 » Thu Dec 31, 2009 12:45 am
Like I said, I tried all different combinations of titles and tracks. The disc shows two large titles; both are around ~26gb, one has 10 chapters, the other has 27. Both produce a file about 122mb (10 seconds long). When making the mkv, the "source" size says ~26gb. Everything seems right. Since this post, i have ripped two other blurays so I know my hardware is working.
Tommye1078
#6 Post by Tommye1078 » Thu Dec 31, 2009 3:59 am
I ripped terminator salvation a week ago and had no problems. It was using to old firmware???
comporder1
#7 Post by comporder1 » Thu Dec 31, 2009 4:38 am
Are you saying it might be the drive firmware too old? I just checked, it is the latest. Also, latested MakeMKV. Any other ideas?
comporder1
#8 Post by comporder1 » Thu Dec 31, 2009 5:12 am
Here are some screenshots. May this will give a little more in-site.
Tommye1078
#9 Post by Tommye1078 » Thu Dec 31, 2009 3:38 pm
I meant to say I was using the old version of makemkv. I'm sure this doesnt matter. It's very strange.
comporder1
#10 Post by comporder1 » Fri Jan 01, 2010 4:46 pm
Ideas anyone??!!
setarip_old
#11 Post by setarip_old » Fri Jan 01, 2010 9:31 pm
Since I and others have had no such problem when processing the R1 version of this BluRay disc, I'd suggest you:
1) Re-process your original BluRay disc with MakeMKV.
If you again have the same problem,
2) Return your original BluRay disc to the place of purchase in exchange for a new replacement.
dbone1026
#12 Post by dbone1026 » Sat Jan 02, 2010 3:03 am
I can confirm I had the same exact problem with Terminator Salvation Blu Ray. Ended up throwing into Clown_BD and then using MKVMerge, worked perfectly. Not an issue with the disc.
Cheers,
Damian
blog - http://dbone1026.blogspot.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
comporder1
#13 Post by comporder1 » Sat Jan 02, 2010 3:23 am
dbone1026 wrote:I can confirm I had the same exact problem with Terminator Salvation Blu Ray. Ended up throwing into Clown_BD and then using MKVMerge, worked perfectly. Not an issue with the disc.
thanks for the confirmation dbone1026. It's good to know it's not me or my hardware. I'll give your process a try.
Comporder1
