Hi there,
I was using MakeMKV under Squeeze without Problems but under Wheezy it got weird.
I did a fresh Install under Wheezy with Version 1.7.7 (which seems to be the latest according to this forum).
But when I start MakeMKV it tells me that this Version is too old an that I should download the latest Version.
Also, when I try to register my Key I'm told that my key is wrong.
What can I do ?
Problems with new Installation under Debian Wheezy
batesman
batesman
Re: Problems with new Installation under Debian Wheezy
OK,
even no one answered...
It's running again. It seems MakeMKV got an update over the weekend which was yet not linked anywhere.
But here comes the next Problem. When I try to start 1.7.8 (1.7.7 is running) I get a message :
As I already wrote I use Wheezy, which uses "libc 2.13".
I don't want to backport a libc in a system which is not even released.
What can I do ???
/usr/bin/makemkvcon: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /usr/bin/makemkvcon)
/usr/bin/makemkvcon: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /usr/bin/makemkvcon)I don't want to backport a libc in a system which is not even released.
What can I do ???
Will be corrected in the next version of MakeMKV, should be available shortly.
joplass
I am having the exact same issue.
Should we hang tight and wait for that correction? In that case it is worthy. Great app!
My output below:
My output below:
job@Luna:~$ makemkv
job@Luna:~$ makemkvcon
makemkvcon: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by makemkvcon)
makemkvcon: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by makemkvcon)
