Need sqv file for Ice Age 4 Continental Drift
setarip_old
Re: Need sqv file for Ice Age 4 Continental Drift
Hi! Welcome to the MakeMKV beta testing Forum.
Is yours an official, commercial Blu-ray?
I ask because, after searching the 'Net, everything seems to indicate a December 11, 2012 release date, 1and 1/2 months from now...
Yeah, this is a commercial blu-ray.
This is the one sold in Brazil.
Thanks for your reply.
Here is the output from MakeMKV
MakeMKV v1.7.71 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHF" opened in DASPI v1.3 mode.
Optical drive "BD-RE PIONEER BD-RW BDR-206D 1.56" opened in DASPI v1.3 mode.
Downloading latest SVQ(s) to /Users/rsorelli/.MakeMKV ...
Loaded 136 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/rsorelli/.MakeMKV/dump_Ice_Age__Continental_Drift_13965C66A4F960B6.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
I imagine it may take a while for "mike admin" to be able to obtain and work on this one...
- Contact:
You need to send the dump file "/Users/rsorelli/.MakeMKV/dump_Ice_Age__Continental_Drift_13965C66A4F960B6.tgz" to svq@makemkv.com per instructions at http://www.makemkv.com/svq/
Mike,
I sent the email on October 27th.
Can you double check?
The subject is "Need SQV file for Ice Age 4 Continental Drift" and it has 25MB file attached.
Sent the email again ...
- Contact:
SVQ updated.
Hi there
Today I just bought the German Retail Bluray (Ice Age 4 voll verschoben). And I tried to backup it without success. I downloaded the latest MakeMKV-Release (1.7.9) but I recieve the same Error as rsorelli.
I will send you the dump in a few minutes at mail. Subject: "Ice Age 4 - German".
Greetings
Greetings
Still not working ...
Sending new dump to the email:
MakeMKV v1.7.9 darwin(x86-release) started
Loaded 140 SVQ file(s)
Just ran MakeMKV in debug and here is the output:
Debug logging enabled, log will be saved as /Users/rsorelli/MakeMKV_log.txt
DEBUG: Code 89 at .yAOG%A0&t$V`~c{!7:29397265
DEBUG: Code 89 at .yAOG%A0&t$V`~c{!7:121262923
DEBUG: Code 0 at .yAOG%A0&t$V`~c{!7:29394643
DEBUG: Code 0 at g6bV<:JFTF4O8YP3258C:121262486
DEBUG: Code 0 at z=7kpi{\*Er[=|8H:29400531
DEBUG: Code 0 at z=7kpi{\*Er[=|8H:29398254
DEBUG: Code 0 at z=7kpi{\*Er[=|8H:213139690
DEBUG: Code 0 at Rd<A9$Om@*$}kk#! N:121265752
DEBUG: Code 0 at C0Hj3.t|d<E#X/rz:29396897
setarip_old
Perhaps that very early Brazilian release is flawed.
On the other hand, it seems like the very early German release can now be processed properly...
ilcontegis
I got the BD in Japan and I get the same error.
I sent the dump as requested. Any help?
Thank you
MakeMKV v1.7.10 linux(x64-release) started
Loaded 163 SVQ file(s)
Saved BD+ dump file as /home/name/.MakeMKV/dump_Ice_Age_4_16C9C9EA40CFD174.tgz
Failed to process BD+ code, please check /svq/ for updated program and SVQ files
Thank you
