Limitless problem and others
Hello
I tried MakeMKV with a dozen BR, no problems.
I bought MakeMKV 60 €, and I am not come to rip the town (two different br), and tonight, I have an error message with "Limitless"
MakeMKV v1.7.8 win(x64-release) started
File 00001.mpls was added as title #0
File 00007.mpls was added as title #1
Title 00009.mpls is equal to title 00001.mpls and was skipped
File 00003.m2ts was added as title #2
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '61440'
What's wrong ?
Cordially
Doryphore
What's wrong ?
Cordially
Doryphore
- Contact:
Re: Limitless problem and others
Thank's i'll trie
Hello
I bought a new blu ray burner: LG BH10LS38 and no problem or error disc.....
So the problem came from my old optiarc blu ray player, who was former
Thank's
Doryphore
Thank's
Doryphore
setarip_old
@doryphore
Glad to hear that a new drive solved your problem - but I'm curious to know if you first attempted to run a cleaning disc on your old drive...
Yes, I tried to manually clean the BR: switch off with soap and water, drying carefully, polishing, etc. ..... without success
I was even ready to buy a machine, but apparently it does not work well with blu ray :
http://www.amazon.com/Digital-Innovatio ... dr+blu+ray
setarip_old
It sounds like you're talking about cleaning the Blu-ray disc.Yes, I tried to manually clean the BR: switch off with soap and water, drying carefully, polishing, etc. ..... without success
I'm talking about cleaning the innards of your Blu-ray READER/BURNER.
My apologies if I haven't understood you correctly...
Sorry
It is I who am sorry, I'm French and do not understand all the subtleties of the language of Shakespeare
I also cleaned the lens bluray drive, which has no dirt ....
This is a bluray player in my laptop brand optiarc BD 5500s that can not be updated (firmware 1b2) as acer does not provide drivers, and drivers are incompatible sony
So I installed a new reader / writer in my tower
setarip_old
Good solution - Enjoy the new drive!
Hello
I've got a problem with invictus BR : can't create a mkv file
Also i can't create a image with imgburn, yet the disk is new and thery clean....
setarip_old
@doryphore
This thread is only about "Limitless" Blu-ray disc.
You should create a new thread - or perhaps the moderator can move your post to a new thread...
