Nothing to see here folks, move along.
Problem is the DVD's fault. Alternate audio track is strange, and MakeMKV sets the alternate stream as default so it looked like an error. It's actually fine.
<snip>
setarip_old
Re: Empy audio stream detection not working....
@electroglyph
Hi!
Try lowering the "Minimum Title Size" from 300 seconds (5 minutes) to TWO seconds...
Hi!
electroglyph
Re: <snip>
Yeah, I had that set very high for some previous discs. The problem ended up being strange secondary audio streams on the disc which were playing by default instead of the normal one. So no problem at all on MakeMKV's end.
setarip_old
Re: <snip>
Glad to hear you resolved your dilemma ;>}
