ffmpeg, 24-bit FLAC: source code?
Romansh
#1 Post by Romansh » Fri Aug 17, 2012 11:31 pm
Where can I find the source code for the modified ffmpeg build that ships with MakeMKV 1.7.7?
Romansh
Re: ffmpeg, 24-bit FLAC: source code?
#2 Post by Romansh » Tue Aug 21, 2012 4:00 pm
mgchristensen
#3 Post by mgchristensen » Thu Oct 18, 2012 11:03 pm
Regarding the FLAC encoder that handles 24-bit audio. It is unclear to me whether the ffmpeg-src tree gets inserted somewhere into the makemkv-oss tree, or is built separately and then MakeMKV is pointed at it. I did a little digging/experimenting, details below.
Additional info:
The configure script in ~/temp/ffmpeg-src needs yasm (http://yasm.tortall.net/). I am running Fedora 17 on a Toshiba A665 laptop, i7-Q740 proc. There was a Fedora 17 package available in the Fedora repository. Once yasm was installed, make executed (with the usual warnings of deprecated calls and array indices out-of-bounds).
Make yields these binary executable files: ffmpeg, ffmpeg_g, ffplay, ffplay_g, ffprobe, ffprobe_g, ffserver, ffserver_g.
There is no reference that I can find in the top-level makefiles for either the oss or the bin parts of MakeMKV to these ffmpeg sources or binaries. Might be elsewhere in the trees, I have not looked yet.
The make and make install instructions worked for both the -oss and -bin parts. The resulting program executed. Under preferences there is a setting in the advanced tab for FFMPEG location, I pointed it at the ffmpeg I built above, as I did not want to chance disturbing any previously installed libraries. Found a dtshddec.dll, pointed it at that as well.
BTW, I also disabled Enable UPnP under the Streaming tab and Allow contacting web server for updates under the General tab. Restart MakeMKV. Blu-ray seemed to rip OK.
Romansh
#4 Post by Romansh » Tue Nov 06, 2012 12:20 am
