DVDs subtitles skipping
hecya
Post by hecya » Thu Oct 18, 2012 3:32 pm
I am using version 1.7.8 on Mac running MacOS 10.8.2. Some DVDs converted (not all of them) have some problems with subtitles when playing on a WD TV Live (latest generation).
The problem is that only a few of the subtitle texts are actually displayed. That is, a subtitle text appears at the proper time, then disappears and the next subtitle does not appear and this goes on for several seconds (about 20 or even more) until eventually a text is displayed that is correct in time but the intermediate ones are missing. This makes impossible to follow the story.
All mkv files that I have with this problem play fine on VLC showing all the subtitles texts. This problem is not random and always happens on the same files on the same timing. So I conclude that is something on the files themselves that is not decoded well by the player.
The latest movie I had with this issue is "The Double" and I have splitted a short scene (33 seconds) with a lot of dialog and with just a few subtitle texts displayed. The file size is 25.5 MB. How can I upload it?
Romansh
Re: DVDs subtitles skipping
Post by Romansh » Thu Oct 18, 2012 5:10 pm
Are you using the new WDTV conversion profile or the default?
Chetwood
Post by Chetwood » Fri Oct 19, 2012 6:46 am
This is unrelated to the WDTV profile since unlike with PGS subs, the WDTV displays VobSubs also when they are uncompressed. However, quite some time ago I read about VobSub dropouts (due to missing end times of some items) having been fixed. Are you on the latest firmware?
hecya
Post by hecya » Fri Oct 19, 2012 11:23 pm
I am using the default profile and the firmware is the latest. The same problem happens with the same files on an old 2nd generation WD TV.
Chetwood
Post by Chetwood » Sat Oct 20, 2012 6:14 am
You should post this on the official WDTV forum.
