Total Recall (1990) - Copy protection errors
popweasel
#1 Post by popweasel » Thu Oct 18, 2012 2:29 pm
I just installed the latest makemkv on Ubuntu 12.04 64bit. I tried to watch Total Recall (1990) and received the following:
MakeMKV v1.7.8 linux(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..09D748AF5887FC24611D486B52F45943AF9 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..01878568CF9DAD36D7E4BC136893D2F0F56 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0F03D1D3CE5D2AE9D44A9FE043D54CFA3BA to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..07F387132090DC2F513E840EAA514747A83 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0BA31FCF68445D18B81684CE2E664AE796B to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0C82000D8972E8D517DDF86905421BCB59F to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..04E68DCF71B8F43379C3823023A199209CD to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..036A02F166C3B49BCD8127192B35DF83975 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0FEFC60B8E7AAA08056746ADA3F22B88FC1 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0D85A0F0B3092980562DEC956550DBCEC99 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0A6673F4B11B4A353AC24F1CA0038445512 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..03FEA797847D31DBAA12E9537CE38B09465 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0275BE6CE2FFBB17F45FA770743541F1AF9 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0C864C61518F7B53D521C955140916FB7D6 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0981219888BE522306B8294FFED04295BCC to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0B03A4EA1CD29A06228DBDAF69835C3F803 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002440 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..054D1F397ACB0A0D17401B5752CB044B478 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0BFDD713137489190CE7226093F47310993 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0252AD05D857922BA0936B21170B67BC20B to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..065B2035DE32A18C2E09E37C8E0DE6C28C7 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0FABF250EB2FAEBB546AD9E63FC08C52025 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..05C58996C080CA1F709F69776ABAD34F743 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..09C26D5F1F97221E6E863E97C8CD3953C41 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..09A02D250B1469746D6DC962A5E96CF5429 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0172314826970AF409EDB59C685A03E59DF to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0749711222A171CE56F6D88A7401AF2F980 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0FCB9F41A89A749B35FEE685FB712BA2FD1 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..04C0122E3A3425355169A1920E15C072FA8 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0E9A14A7A000CA604854B988EB91E50BF99 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0D02DC53697EDA15CFD4905191D34F73F60 to device 'SG:dev_11:0'
Any suggestions?
popweasel
Re: Total Recall (1990) - Copy protection errors
#2 Post by popweasel » Thu Oct 18, 2012 3:20 pm
I read a similar discussion and tried running makemkv as root with the same results. I tried Swordfish and Total Recall (1990) with same results.
Debug log started at Thu Oct 18 15:12:13 2012 , written by MakeMKV v1.7.8 linux(x64-release)
001005:0000 MakeMKV v1.7.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/likewise-open/MYSTIKCREATURES/popweasel/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQEEAAADATAwMDQ3MzY5ICAgIAEKAAw=
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..07FC0F186EE5F2A3E6F0D2EA79A2CD9038A to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 0 at @|)QKZoP~cUXJ&Mh2:213130743
001003:0020 DEBUG: Code 0 at _'&M^e[[r2'2-Qi4~X:29395034
001003:0020 DEBUG: Code 0 at _'&M^e[[r2'2-Qi4~X:121262394
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0E18B5AC5BA342330BF41E0E90F74F8472F to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 1 at _'&M^e[[r2'2-Qi4~X:121262394
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..07200F4FD5B467F84E18E669A89AD9D3AC5 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 2 at _'&M^e[[r2'2-Qi4~X:121262394
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0DF2011C210CB612B2EC25B77DD66B57F62 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 3 at _'&M^e[[r2'2-Qi4~X:121262394
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..013C518A7A9A4C0CC7E54D0718CA9940143 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 4 at _'&M^e[[r2'2-Qi4~X:121262394
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..055395DE7A4905CF8F76E87060B1C885068 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..092E3DCE02666E576477CB48B7846D599C6 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..09E5956F0EED1CCB2354A9DED738944825E to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0D4035FF8DA2393A33C1F63A088063ED2BC to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..026EC442F81891B3A7CF0D2A4C094A85E0E to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..023F1E76AFA0B75521A156267967517D313 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0FCD167EDF4D9BB1B18167F6F6DD37C4D80 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..042765D46D71D4F0C252AC0F84617237DD9 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0219BC4452F987C56062A5D63457EB4FA6A to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..01BAA39CE45E52F875609BC81469B116822 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..027DEDDC9ACBD0A2E51DCCD74409BC5C900 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002440 to device 'SG:dev_11:0'
DEBUG: Code 0 at @|)QKZoP~cUXJ&Mh2:213130283
001003:0020 DEBUG: Code 0 at _'&M^e[[r2'2-Qi4~X:121264234
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0F498243CD07073BD078D0CA94F27659C1C to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0C1A263FEF70AA3D495C212F8CE99AB612F to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..022EEC948ACB8E305062FCDF07C7C0D1700 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0AAFEBAB9DA765D3C223940B4AC4501184E to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..01CFAA84D0CF93796C1A648E7ED6293B1E1 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0FB4C84FDE1F762DE8146E0880253C0B016 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..07A557107290C23F56F2C0815383120F822 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0EC1EC0B994F738BAD1D2ED59619F57798C to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..06559903CF9EFCC1300C29E01BC67C40902 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..096264A0B5332BB5E0E94E90C05D7F69E03 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..096D47C0A0B1F144CD3959BCB6FF016690F to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..00AEED4224653A0B5EA2138E55119B36555 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..024C75D5ECAE4BABC6C9D082C8BB5733A2A to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..01B4472CA885AE0737043BF66BC9319D510 to device 'SG:dev_11:0'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at }wz1;KK&b/w;K7!{:121263544
001003:0020 DEBUG: Code 0 at }wz1;KK&b/w;K7!{:29396897
Application exited at Thu Oct 18 15:14:43 2012
