Fire & Ice
Fire & Ice
I have unsuccessfully tried to make a backup of this movie from two different originals, both times the copy fails at the same point, while writing the file to disk at about 170 MB.
Debug log started at Sat Dec 18 00:09:29 2010 , written by MakeMKV v1.6.2 darwin(x86-release)
001003:0020 DEBUG: Code 6053888 at %a(hQ[u}Mej6J/Dkv"A#(:":213130007
001005:0000 MakeMKV v1.6.2 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jeffr/MakeMKV_log.txt
005075:0000 The new version 1.6.3 is available for download at http://www.makemkv.com/download
DISCID=E4FF26FF55D8D738908570F010C0DD278C985776
003307:0000 File 00007.mpls was added as title #0
003309:0000 Title 01007.mpls is equal to title 00007.mpls and was skipped
003025:0000 Title #00000.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00004.m2ts was added as title #1
003025:0000 Title #00005.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.m2ts was added as title #2
005014:0000 Saving 1 titles into directory /Users/jeffr/Movies/Fire_&_Ice
001003:0020 DEBUG: Code 1000 at HZqedXoW1w{J' +4$?b:121263590
001003:0020 DEBUG: Code 1167892 at HZqedXoW1w{J' +4$?b:29396805
001003:0020 DEBUG: Code 2948413080 at HZqedXoW1w{J' +4$?b:29396828
001003:0020 DEBUG: Code 0 at ^GR>u(ewS%2yJq6}V)P'2:213134791
001003:0020 DEBUG: Code 256430080 at po%se2&yf%.Sq}@|u ^:29394873
001003:0020 DEBUG: Code 24020 at po%se2&yf%.Sq}@|u ^:29394896
001003:0020 DEBUG: Code 0 at ^GR>u(ewS%2yJq6}V)P'2:29397449
005003:0000 Failed to save title 0 to file /Users/jeffr/Movies/Fire_&_Ice/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Dec 18 00:11:38 2010
setarip_old
Re: Fire & Ice
Hi!
Have you installed and tried using v.1.6.3?
Re: Fire & Ice
Yes I did notice that in the log and yes I tried it and got the same result. As this was tried on two different copies just wondering if there is a fake 'bad sector' type protection?
setarip_old
Re: Fire & Ice
To the best of my knowledge, no protection of that nature has thusfar been used on Blu-ray discs...just wondering if there is a fake 'bad sector' type protection?
- Contact:
Re: Fire & Ice
Is this a regular commercial blu-ray disc?
Re: Fire & Ice
I'm having the same problems at the same point in the extraction. 174.7Mb into the disc:
Saving 1 titles into directory C:/Media/Fire & Ice
Failed to save title 0 to file C:/Media/Fire & Ice/title00.mkv
DEBUG: Code 1000 at <D(>7~k/ojF2_$1l*"w:121263590
DEBUG: Code 1167892 at <D(>7~k/ojF2_$1l*"w:29396805
DEBUG: Code 2948413080 at <D(>7~k/ojF2_$1l*"w:29396828
DEBUG: Code 0 at #!:w_I!/UZEl)eP5|#p[2:213134791
DEBUG: Code 256430080 at _/n2|Uo5]}T`p\/@;j>:29394873
DEBUG: Code 24020 at _/n2|Uo5]}T`p\/@;j>:29394896
DEBUG: Code 0 at #!:w_I!/UZEl)eP5|#p[2:29397449
Let me know if there is anything you need me to test, troubleshoot or validate to help resolve the problem.
- Contact:
Re: Fire & Ice
Looks like a disc mastering error. What region is this disc?
Re: Fire & Ice
I got it as a used disc from Blockbuster Canada. So it should be North America unless their rental discs are unique. I have not tried playing it in a be player but I assume it works.
Chest Rockwell
Re: Fire & Ice
Looks like this problem still persist almost two years after original post. Log attached.
__________________________________
MakeMKV v1.7.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Man Cave/MakeMKV_log.txt
Title #00000.m2ts has length of 9 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00001.m2ts has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00003.m2ts has length of 101 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00004.m2ts has length of 123 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00005.m2ts has length of 65 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00006.m2ts has length of 45 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00008.m2ts has length of 96 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00009.m2ts was added as title #1
Saving 1 titles into directory C:/Users/Man Cave/Desktop
DEBUG: Code 1000 at zyx^)BgD_F])\bL 6Vr:29395839
DEBUG: Code 1167892 at zyx^)BgD_F])\bL 6Vr:213133664
DEBUG: Code 2948413080 at zyx^)BgD_F])\bL 6Vr:121265476
DEBUG: Code 0 at meYU{PO'Bt}6Lre7169"(:29399105
DEBUG: Code 256430080 at r+z5!L-ZQLv095,ry2-:213131111
DEBUG: Code 24020 at r+z5!L-ZQLv095,ry2-:213131134
DEBUG: Code 0 at meYU{PO'Bt}6Lre7169"(:29397955
Failed to save title 0 to file C:/Users/Man Cave/Desktop/title00.mkv
- MakeMKV_log.txt
- (2.52 KiB) Downloaded 565 times
Re: Fire & Ice
So "Fire & Ice" == "Man Cave" now?Chest Rockwell wrote:Looks like this problem still persist almost two years after original post. Log attached.
