I have been getting errors on Dr Seuss Lorax DVD. After it reads the disc I get the "Fatal error occurred. Program will now exit" window.
Debug log started at Sat Oct 13 23:17:39 2012 , written by MakeMKV v1.7.7 win(x64-release)
001005:0000 MakeMKV v1.7.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Justin/MakeMKV_log.txt
003025:0000 Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #3 was added (22 cell(s), 1:26:06)
003028:0000 Title #4 was added (8 cell(s), 0:06:06)
Title skip vts=5 pgcn=1 hash=3E95A862A1D6FADF
003025:0000 Title #6 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #8 was added (1 cell(s), 0:02:15)
Title skip vts=6 pgcn=3 hash=828677546A3764A0
003025:0000 Title #9 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #10 was added (1 cell(s), 0:02:06)
Title skip vts=6 pgcn=5 hash=F02D1FAE0F82F67D
003028:0000 Title #11 was added (1 cell(s), 0:02:05)
Title skip vts=6 pgcn=6 hash=9AD25B062E7736C2
003025:0000 Title #12 has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #14 was added (8 cell(s), 0:10:31)
Title skip vts=6 pgcn=9 hash=E0CEAD781E588A2C
003028:0000 Title #15 was added (1 cell(s), 0:04:28)
Title skip vts=7 pgcn=1 hash=9A49B80C301A1F26
003028:0000 Title #16 was added (2 cell(s), 0:03:30)
003028:0000 Title #17 was added (2 cell(s), 0:03:28)
003028:0000 Title #18 was added (2 cell(s), 0:03:29)
003028:0000 Title #19 was added (4 cell(s), 0:10:25)
003025:0000 Title #20 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/1 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/2 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/3 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/4 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/5 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/6 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/7 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/8 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/9 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/10 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/11 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/12 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/13 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/14 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/15 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/16 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/17 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/18 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/19 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/20 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/21 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/22 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/23 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20/24 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #21 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
csf9
csf6
Application exited at Sat Oct 13 23:19:14 2012
Dr Seuss Lorax Failure
- Contact:
Re: Dr Seuss Lorax Failure
Please try 1.7.8 and see if it changes anything.
Same if not worse results with 1.7.8. After the "Operation successfully completed," it goes not responding for a few seconds. Then once i get the DVD titles breakdown I get the same fatal error occurred message.
