The town bluray
doryphore
The town bluray
Post by doryphore »
Hello
impossible to rip "the town" ?
The BR does not have default (scratches or dirt)
The file log:
File 00007.mpls was added as title #0
File 00101.mpls was added as title #1
File 00200.mpls was added as title #2
File 00100.mpls was added as title #3
Title #00027.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory E:/Video/THE_TOWN
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '17859016704'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '17860460544'
Failed to save title 3 to file E:/Video/THE_TOWN/THE_TOWN_t03.mkv
0 titles saved, 1 failed
Doryphore
doryphore
Re: The town bluray
Post by doryphore »
I have another BR of the town, and i've got the same error :shock:
setarip_old
Re: The town bluray
Post by setarip_old »
Hi!
The log indicates that at least part of the disc is unreadable, indicating that either the disc is flawed or your drive is having problems or failing.
Try running a cleaning disc on your reader. Maxell sells one for about $10US...
doryphore
Re: The town bluray
Post by doryphore »
Hello
Yes, I see errors in disk access
It's weird, I had 1 BR the town and I exchanged: they all have the same two problems: impossible to rip, there's always a mistake .... yet their surfaces is perfect ... ..
More on other forums ripping software: same problems encountered with the BR "the town" .....
I bought a new drive, It's a shame because I just bought MakeMKV :x
