Just started a freshly installed V1.7.7 win(x86-release) on a virgin machine.
It tells me that the Program is old and I should download the actual version, or register.
Unfortunately I can just download version 1.7.7.
Thanks a lot for a hint!
regards
romeo-kilo
v1.7.7 is old and I should download the actual version
romeo-kilo
dtdyson
Re: v1.7.7 is old and I should download the actual version
I am encountering the same issue - dialogue box comes up as attached. Suggestions?
happinesssam
Exactly the same problem.
zzapxxx
I will point you in the direction of this post:
viewtopic.php?f=5&t=1053
happinesssam
Maybe change the wording of that post to contain the phrase 'registration key' as well as 'activation key', since that's what's on the alert pop-up.
That way we could find it by searching the forums easier.
syklab
Same problem and not able to reinstall nor use the beta key.
Did you try resetting the system date back to when the old beta key was usable, then try installing the new key?
I do agree that a better way of dealing with an expired key would be to prompt for the new one, rather than simply shutting down without giving you the option to put in the new key.
Of course, I found a better work-around... I registered!
romeo-kilo
Hi zzapxxx,
thank you very much for this hint.
regards
Romeo Kilo
regards
Romeo Kilo
This normally should never happen - we missed a release (by two days). The 1.7.8 is now available.
