This Means War
divcss
This Means War
Post by divcss »
I have problems in encoding "This Means War" BD+.
Here is the corresponding dump file:
http://uploaded.to/file/u1thwn2e
Any suggestions?
setarip_old
Re: This Means War
Post by setarip_old »
Hi!
What SPECIFIC problems are you having?
ftz.de
Re: This Means War
Post by ftz.de »
I have the same problem. :(
@divcss: Have you mailed the dumb file to svq@makemkv.com, as described on http://www.makemkv.com/svq/ ?
@setarip_old: MakeMKV says:
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as ...
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
theforce
Re: This Means War
Post by theforce »
I've also got the same problem, and I've email the tgz dump (using a different email address)
ephemeris
Re: This Means War
Post by ephemeris »
Still no workaround after three months? I submitted my dump file the week this disc came out. I just tried MakeMKV 1.7.7 (OSX) and it still fails.
setarip_old
Re: This Means War
@ephemeris
According to the list at the following forum link,you'll find that this title is one that has supposedly been "taken care of":
http://viewtopic.php?f=5&t=612#p1657
ephemeris
Re: This Means War - Problem resolved
Post by ephemeris »
Problem solved. Looks like my data directory was corrupt. I deleted everything so that when I launched MakeMKV it reloaded all the svq files.
setarip_old
Re: This Means War
@ephemeris
Glad to hear that you've resolved your problem ;>}
