Prometeus crash
voip-ninja
Re: Prometeus crash
Post by voip-ninja »
I upgraded to 1.7.7 and it downloaded some new SQV files and it is now ripping.
What is odd is that I'm set up to be notified of automatic upgrades, but for whatever reason the version change did not get recognized and so I was never under the impression that a newer version was available.
In any event, all's good.... ripping now!
bartman
Re: Prometeus crash
Post by bartman »
3D version is still not working. Sent logfile and link to dump.
twotower
Re: Prometeus crash
Post by twotower »
I just sent you the BD+ dump file for Prometheus today. Same issue as everyone else.
Peace
MJBadamo
Re: Prometeus crash
Post by MJBadamo »
Working just fine now. Thanks a bunch!
Re: Prometeus crash
Post by mike admin »
bartman wrote:3D version is still not working. Sent logfile and link to dump.
Please see viewtopic.php?f=8&t=5493 for update on 3D version.
haikuginger
Re: Prometeus crash
Post by haikuginger »
Still doesn't work for me. Here's the log:
Debug log started at Fri Oct 12 13:28:36 2012 , written by MakeMKV v1.7.7 win(x64-release)
001005:0000 MakeMKV v1.7.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Jesse/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=PmaS/18j5rmNADVN6WrFrOUruRP7RDg0rtp8VrDtkwEgh6f21pCgMlV57y9WrOjAuWPt7cuH6/pcOZ8d1n+hMCM1aKWOHrryExnoK7nE7iNiRCRv969PKDqGm4AmBMUjKPO7sQnSz9Id2TMR/nIK1cbgusHwraxwMg==
003338:0000 Downloading latest SVQ(s) to C:\Users\Jesse/.MakeMKV ...
003317:0000 Loaded 124 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
001003:0020 DEBUG: Code 89 at |19~.e~B0kB?qG#eL`:29397265
001003:0020 DEBUG: Code 89 at |19~.e~B0kB?qG#eL`:121262923
001003:0020 DEBUG: Code 0 at |19~.e~B0kB?qG#eL`:29394643
001003:0020 DEBUG: Code 0 at VQ8`[Z>&o,%^97:N6}sW:121262486
001003:0020 DEBUG: Code 0 at gV%VSomF4%^v^a[S:29400531
001003:0020 DEBUG: Code 0 at gV%VSomF4%^v^a[S:29398254
001003:0020 DEBUG: Code 0 at gV%VSomF4%^v^a[S:213139690
003325:0000 Failed to process BD+ code using generic SVQ from builtin/00000.svq
001003:0020 DEBUG: Code 0 at ;]D-G092s*LE\HmlM%:121265752
003332:0000 Saved BD+ dump file as C:\Users\Jesse/.MakeMKV/dump_Prometheus_986AF3EED696C860.tgz
003321:0000 Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
001003:0020 DEBUG: Code 0 at ^ES:6?mKZ|!<r&e>:29396897
Application exited at Fri Oct 12 13:30:10 2012
I've cleared the data directory, and made sure to reinstall the application, even though I was already on 1.7.7. Windows 7 x64. Dump and log sent to support@makemkv.com
kkimmel
Re: Prometeus crash
Post by kkimmel »
:P FYI to all if you may use Norton Internet Security.
I could not decrypt Prometheus using MakeMKV, AnyDVD HD, or DVDFab HD. Wasted a whole day on this. This morning I noticed that my NIS Live Update had a failure installing an NIS update. Corrected the issue and went back to the decryption software forums looking for any updated Promethius solutions.
In the Slysoft forums I came across a post suggesting that a user's firewall was blocking online access for AnyDVD HD to acquire the updated decryption information. Soooo..., I went into my Norton's firewall program access section and changed the permission for AnyDVD HD from Auto to Allow. This worked. :P :P
If you are running NIS, try this for MakeMKV.
truckerCLOCK
Re: Prometeus crash
Post by truckerCLOCK »
Still not working for me either. Is it just the 3D version that has BD+ because I have the 2D ver. and it shows BD+ v2012.9
Re: Prometeus crash
truckerCLOCK wrote:Still not working for me either. Is it just the 3D version that has BD+ because I have the 2D ver. and it shows BD+ v2012.9
We've never seen 2012.9 - please send the dump.
zumosol
Re: Prometeus crash
Post by zumosol »
It's working now :D
THANX !!
haikuginger
Re: Prometeus crash
Mine (BD+ 2012.9) is working now as well! Thanks very much!
truckerCLOCK
Re: Prometeus crash
Working now ....Thanks also !!!
Dodgson_here
Re: Prometeus crash
Post by Dodgson_here »
This worked perfectly with 1.7.8. Thank you for fixing this so quickly!
dhisharp
Re: Prometeus crash
Post by dhisharp »
I am getting following error:
MakeMKV v1.7.9 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE BH10NS30 EL00" opened in DASPI v1.3 mode.
Automatic SVQ downloading is disabled or failed.
Saved BD+ dump file as /Users/D/.MakeMKV/dump_Prometheus_4B141D9A38A12BF5.tgz
Opening files on harddrive at /Volumes/PROMETHEUS
setarip_old
Re: Prometeus crash
Post by setarip_old »
Hi!
Check your settings for SVQ downloading - and then try again...
