Prometeus crash
crowfax
Re: Prometeus crash
Post by crowfax » Wed Oct 10, 2012 3:23 pm
MJBadamo wrote:I'm brand new here and i'm having the same problem. i tried sending the dump file (size of 39.1 mb) but it was "too large" and wouldn't send. :-(
any suggestions?
i would post it on here but i can see there's already a few up.
thanks a bunch.
Use a service like www.sendfile.com
crowfax
Re: Prometeus crash
Post by crowfax » Wed Oct 10, 2012 3:25 pm
jrwalker4 wrote:(No "Dump" file created for PROMETHEUS DVD which appeared to open normally.)
BD+ dump files are only created for discs that have BD+. DVD's do not have BD+ protection.
wertert
Re: Prometeus crash
Post by wertert » Wed Oct 10, 2012 7:10 pm
+1 for me. New member here. Hi All
Problem is exactly as described above. 64 bit win 7
Have attempted to email 52Mb dump file ( zipped )
still sending now !
havok3114
Re: Prometeus crash
Post by havok3114 » Wed Oct 10, 2012 7:13 pm
William, I used http://www.sendspace.com/ to send my dump file in. Upload it there and send the link.
AAlchemy
Re: Prometeus crash
Post by AAlchemy » Wed Oct 10, 2012 7:30 pm
I used my google drive.
hub srt
Re: Prometeus crash
Post by hub srt » Wed Oct 10, 2012 9:11 pm
Having the same issues for the BD version of the movie. It will crash MKV.
This is what is gives me.
MakeMKV v1.7.7 win(x86-release) started
Loaded 111 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Re: Prometeus crash
Post by mike admin » Thu Oct 11, 2012 8:55 am
SVQ updated for all versions. If it still crashes, please reply here.
bartman
Re: Prometeus crash
Post by bartman » Thu Oct 11, 2012 12:37 pm
Is the 3D disk 'fixed' too? MKV ends with 'Backup failed' due to 'Failed to process BD+ code'.
JamesG269
Re: Prometeus crash
Post by JamesG269 » Thu Oct 11, 2012 12:54 pm
Still crashes, as of a few minutes ago:
MakeMKV v1.7.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\jgentile/MakeMKV_log.txt
Evaluation version, 29 day(s) out of 30 remaining
Loaded 115 SVQ file(s)
DEBUG: Code 89 at |19~.e~B0kB?qG#eL`:29397265
DEBUG: Code 89 at |19~.e~B0kB?qG#eL`:121262923
DEBUG: Code 0 at |19~.e~B0kB?qG#eL`:29394643
DEBUG: Code 0 at VQ8`[Z>&o,%^97:N6}sW:121262486
DEBUG: Code 0 at gV%VSomF4%^v^a[S:29400531
DEBUG: Code 0 at gV%VSomF4%^v^a[S:29398254
DEBUG: Code 0 at gV%VSomF4%^v^a[S:213139690
DEBUG: Code 0 at ;]D-G092s*LE\HmlM%:121265752
Saved BD+ dump file as C:\Users\jgentile/.MakeMKV/dump_Prometheus_986AF3EED696C860.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
DEBUG: Code 0 at ^ES:6?mKZ|!<r&e>:29396897
DEBUG: Code 233 at cTvFCJypub2bRUkXhB+L4+2S:0
Have uploaded the crash dump to SkyDrive: https://skydrive.live.com/redir?resid=8 ... 09DB96!209
havok3114
Re: Prometeus crash
Post by havok3114 » Thu Oct 11, 2012 3:36 pm
My blu-ray worked now! Thanks
setarip_old
Re: @mike admin Prometeus crash
Post by setarip_old » Thu Oct 11, 2012 5:58 pm
@mike admin
Regarding the single disc, 2D U.S. Blu-ray version of "Prometheus":
Using v.1.7.7, I have just succesfully created both a FULL DISC backup and a MOVIE-Only backup (00800.MPLS/00800.M2TS).
Thanks for your great efforts ;>}
ephemeris
Re: Prometeus crash - Still crashing for me
Post by ephemeris » Thu Oct 11, 2012 6:17 pm
I have the 2 disk version using MakeMKV 1.7.7 under OSX 10.7.5.
The log gets to this point
MakeMKV v1.7.71 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/norman/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH61N PA03" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI v1.3 mode.
Downloading latest SVQ(s) to /Users/norman/.MakeMKV ...
Loaded 64 SVQ file(s)
DEBUG: Code 89 at GA,nz+oGf4W*:p~(MS:29397265
DEBUG: Code 89 at GA,nz+oGf4W*:p~(MS:121262923
DEBUG: Code 0 at GA,nz+oGf4W*:p~(MS:29394643
DEBUG: Code 0 at (i*Zg9#vSpwy0lGMochR:121262486
DEBUG: Code 0 at xS6"F{b)4t.*%ktG:29400531
DEBUG: Code 0 at xS6"F{b)4t.*%ktG:29398254
DEBUG: Code 0 at xS6"F{b)4t.*%ktG:213139690
And then I get a modal dialog saying "Fatal error occurred, program will now exit."
setarip_old
Re: Prometeus crash
Post by setarip_old » Thu Oct 11, 2012 7:01 pm
@ephemeris
Hi!
Your log includes the following line:
. I believe that the current number of SVQ files is in the 130s.
Do you have your MakeMKV set up to receive SVQs? (I'm not sure that this is still required or if it's different for MACs)
ephemeris
Re: Prometeus crash
Post by ephemeris » Thu Oct 11, 2012 7:42 pm
I do have the update feature enabled in Preferences… although I didn't always in the past. I have no idea if the number reported is different for different platforms but it is interesting.
ephemeris
Re: Prometeus crash
Post by ephemeris » Thu Oct 11, 2012 11:31 pm
Setarip,
Your instincts were correct. I quit MakeMKV and cleared the data directory then relaunched Make MKV. It looks like the svq files were corrupt somehow. It looks like it may rip now. Cross your fingers...
