Monty Python's Flying Circus - The Complete Boxset (UK PAL 8 DVD Set by Sony Pictures from 2008 - B001EY5VNC)
Apart from Series 1 Disc 1 I have been unable to convert this set to MKV direct from the discs which are brand new and undamaged.
I have attached a zip file with a log file for each disc in the set for Series 1-4
- MP.zip
- MakeMKV Log
- (54.81 KiB) Downloaded 670 times
Re: Monty Python's Flying Circus - The Complete Boxset
I have the same box set with the exact same issues - disc 1 series 1 rips fine, all others fail. I compared the OP's debug logs with a log I took for one disk and they are basically the same - do you need a second set of debug reports or is this OP log files enough to address?
I tried this with 1.7.9 and 1.7.10 both on Linux with same failure results.
Same problem here.
(Monty Python's Flying Circus - Box / 7 DVD Set Sony Pictures 2007 / PAL / RC 2 / B000MTFXFG)
MakeMKV v 1.8.0 (x64-release / Linux).
Season 1 / Disc 2
Season 1 / Disc 2
Title information
Name: Monty Python's Flying Circus Season 1 Disc 2 (English)
Source title ID: 2
Duration: 0:28:52
Chapters count: 12
Segment count: 2
Segment map: 25-55,56
File name: Monty_Python's_Flying_Circus_Season_1_Disc_2_t00.mkv
MakeMKV v1.8.0 linux(x64-release) started
Debug logging enabled, log will be saved as /home/james/MakeMKV_log.txt
IFO file for VTS #15 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 10551302 at :)fzPp?F)$?}6l_|:121269593
DEBUG: Code 0 at :)fzPp?F)$?}6l_|:213138701
DEBUG: Code 0 at f^L#3gG9i,soZm|S/":121262762
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-24 were removed from title start
Title #1 was added (32 cell(s), 0:28:52)
Cells 1-26 were removed from title start
Title #3 was added (35 cell(s), 0:28:41)
Cells 1-25 were removed from title start
Title #4 was added (34 cell(s), 0:30:28)
Cells 1-29 were removed from title start
Title #5 was added (32 cell(s), 0:30:45)
Title #6 was added (32 cell(s), 0:31:23)
Cells 1-27 were removed from title start
Title #7 was added (38 cell(s), 0:29:12)
Title #8 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/1 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/2 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/4 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/5 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/6 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/7 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/8 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/9 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/10 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/12 has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/13 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/14 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/15 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/16 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/17 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/18 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/19 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/20 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/21 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/22 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/23 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/24 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/25 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/26 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/27 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/28 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/29 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Saving 1 titles into directory /home/james/MakeMKV/Monty_Python's_Flying_Circus_Season_1_Disc_2
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '159744'
DEBUG: Code 0 at fl'N:m`K]C=5'cNYh |G:121262739
DEBUG: Code 0 at Ls`zp'de<7^pEhrJ-B#:121261681
DEBUG: Code 0 at fl'N:m`K]C=5'cNYh |G:213130743
DEBUG: Code 78 at fl'N:m`K]C=5'cNYh |G:29393332
DEBUG: Code 0 at SRs%FpPDBaRdr)*l@I6kN:213134584
DEBUG: Code 0 at #ijD#onadBhg4Tl%K|,:29395931
DEBUG: Code 0 at #ijD#onadBhg4Tl%K|,:121262417
DEBUG: Code 0 at #ijD#onadBhg4Tl%K|,:121262210
DEBUG: Code 0 at SRs%FpPDBaRdr)*l@I6kN:213134308
DEBUG: Code 0 at SRs%FpPDBaRdr)*l@I6kN:121266534
DEBUG: Code 0 at 8$$kWsO!gk=5i08R_[1:121262555
DEBUG: Code 0 at 8$$kWsO!gk=5i08R_[1:213132054
DEBUG: Code 0 at 8$$kWsO!gk=5i08R_[1:121263659
DEBUG: Code 0 at 8$$kWsO!gk=5i08R_[1:121265384
DEBUG: Code 0 at f##tIFlMg.zA/at8:213130122
DEBUG: Code 0 at T{c5YE#hC@'Tmn|vP3:121266258
DEBUG: Code 0 at T{c5YE#hC@'Tmn|vP3:213134952
Failed to save title 0 to file /home/james/MakeMKV/Monty_Python's_Flying_Circus_Season_1_Disc_2/Monty_Python's_Flying_Circus_Season_1_Disc_2_t00.mkv
0 titles saved, 1 failed
- Contact:
I have to ask for a lengthy task - please do a test dump for each (failing) episode from this disc per instructions at /onlinehelp/testdump.html
It works with 1.8.1 - Thanks.
