Which Episode?
syztemlord
Which Episode?
#1 Post by syztemlord » Thu Oct 11, 2012 7:59 am
Apologies if this has been asked before but I can't seem to find an answer.
I'm ripping the Star Trek TNG BD and I was wondering if there was a way to see which episode is which, without having to watch them after to check? The don't seem to be in order on the disc. I.e "Title 1" is not necessarily episode 1.
Smithcraft
Re: Which Episode?
#2 Post by Smithcraft » Thu Oct 11, 2012 10:06 am
As far as I know, there is no way to check which one is which without using some sort of player that will tell you what playlist is what. I don't think that teevee shows will be showing up in the AVS BDInfo threads.
Otherwise, there isn't any rhyme or reason to how discs and playlists are mastered. If the designer wants to do episode 1 as playlist 3, episode 2 as playlist 9, episode 3 as playlist 2, and episode 4 as playlist 4 then that's the way that disc gets mastered.
SC
syztemlord
Re: Which Episode?
#3 Post by syztemlord » Thu Oct 11, 2012 11:01 am
Ok, thanks. That's what I thought but just thought I'd ask. :)
