Use a service like www.sendfile.comMJBadamo wrote:I'm brand new here and i'm having the same problem. i tried sending the dump file (size of 39.1 mb) but it was "too large" and wouldn't send.
any suggestions?
i would post it on here but i can see there's already a few up.
thanks a bunch.
Prometeus crash
crowfax
Re: Prometeus crash
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
crowfax
Re: Prometeus crash
BD+ dump files are only created for discs that have BD+. DVD's do not have BD+ protection.jrwalker4 wrote:(No "Dump" file created for PROMETHEUS DVD which appeared to open normally.)
wertert
Re: Prometeus crash
+1 for me. New member here. Hi All
Problem is exactly as described above. 64 bit win 7
Have attempted to email 52Mb dump file ( zipped )
still sending now !
still sending now !
havok3114
Re: Prometeus crash
William, I used http://www.sendspace.com/ to send my dump file in. Upload it there and send the link.
hub srt
Re: Prometeus crash
Having the same issues for the BD version of the movie. It will crash MKV.
This is what is gives me.
MakeMKV v1.7.7 win(x86-release) started
Loaded 111 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Re: Prometeus crash
SVQ updated for all versions. If it still crashes, please reply here.
bartman
Re: Prometeus crash
Is the 3D disk 'fixed' too? MKV ends with 'Backup failed' due to 'Failed to process BD+ code'.
JamesG269
Re: Prometeus crash
Still crashes, as of a few minutes ago:
Have uploaded the crash dump to SkyDrive: https://skydrive.live.com/redir?resid=8 ... 09DB96!209
MakeMKV v1.7.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\jgentile/MakeMKV_log.txt
Evaluation version, 29 day(s) out of 30 remaining
Loaded 115 SVQ file(s)
DEBUG: Code 89 at |19~.e~B0kB?qG#eL`:29397265
DEBUG: Code 89 at |19~.e~B0kB?qG#eL`:121262923
DEBUG: Code 0 at |19~.e~B0kB?qG#eL`:29394643
DEBUG: Code 0 at VQ8`[Z>&o,%^97:N6}sW:121262486
DEBUG: Code 0 at gV%VSomF4%^v^a[S:29400531
DEBUG: Code 0 at gV%VSomF4%^v^a[S:29398254
DEBUG: Code 0 at gV%VSomF4%^v^a[S:213139690
DEBUG: Code 0 at ;]D-G092s*LE\HmlM%:121265752
Saved BD+ dump file as C:\Users\jgentile/.MakeMKV/dump_Prometheus_986AF3EED696C860.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
DEBUG: Code 0 at ^ES:6?mKZ|!<r&e>:29396897
DEBUG: Code 233 at cTvFCJypub2bRUkXhB+L4+2S:0
Failed to open disc-
havok3114
Re: Prometeus crash
My blu-ray worked now! Thanks
setarip_old
Re: @mike admin Prometeus crash
@mike admin
Regarding the single disc, 2D U.S. Blu-ray version of "Prometheus":
Using v.1.7.7, I have just succesfully created both a FULL DISC backup and a MOVIE-Only backup (00800.MPLS/00800.M2TS).
Thanks for your great efforts ;>}
ephemeris
Re: Prometeus crash - Still crashing for me
I have the 2 disk version using MakeMKV 1.7.7 under OSX 10.7.5.
The log gets to this point
MakeMKV v1.7.71 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/norman/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH61N PA03" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI v1.3 mode.
Downloading latest SVQ(s) to /Users/norman/.MakeMKV ...
Loaded 64 SVQ file(s)
DEBUG: Code 89 at GA,nz+oGf4W*:p~(MS:29397265
DEBUG: Code 89 at GA,nz+oGf4W*:p~(MS:121262923
DEBUG: Code 0 at GA,nz+oGf4W*:p~(MS:29394643
DEBUG: Code 0 at (i*Zg9#vSpwy0lGMochR:121262486
DEBUG: Code 0 at xS6"F{b)4t.*%ktG:29400531
DEBUG: Code 0 at xS6"F{b)4t.*%ktG:29398254
DEBUG: Code 0 at xS6"F{b)4t.*%ktG:213139690
And then I get a modal dialog saying "Fatal error occurred, program will now exit."
setarip_old
Re: Prometeus crash
@ephemeris
Hi!
Your log includes the following line:
Do you have your MakeMKV set up to receive SVQs? (I'm not sure that this is still required or if it's different for MACs)
Hi!
. I believe that the current number of SVQ files is in the 130s.Loaded 64 SVQ file(s)
ephemeris
Re: Prometeus crash
I do have the update feature enabled in Preferences… although I didn't always in the past. I have no idea if the number reported is different for different platforms but it is interesting.
ephemeris
Re: Prometeus crash
Setarip,
Your instincts were correct. I quit MakeMKV and cleared the data directory then relaunched Make MKV. It looks like the svq files were corrupt somehow. It looks like it may rip now. Cross your fingers...
