Phineas and Ferb: The Daze of Summer (Main title doesn't)
MorrisCat
Post by MorrisCat »
(Windows MakeMKV v.1.7.7)
Region 1 version
6 titles(which are all trailers/previews) convert, but the main titles does not and is not reported as an available title to convert.
The main title on the DVD plays fine through PowerDVD on the same drive and the DVD visibly looks fine.
The log follows: Thanks.
Calculated BUP offset for VTS #20 does not match one in IFO header.
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 3 chapters
Title #0 (0:22:56) was skipped due to navigation error
Title #2 (0:22:35) was skipped due to navigation error
Title #3 (0:22:35) was skipped due to navigation error
Title #4 (0:22:35) was skipped due to navigation error
Title #5 (0:22:35) was skipped due to navigation error
Title #9 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/4 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/5 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/6 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/7 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 6-end were skipped due to cell commands (structure protection?)
Title #16 was added (5 cell(s), 0:06:01)
Cells 4-end were skipped due to cell commands (structure protection?)
Title #18 was added (3 cell(s), 0:05:23)
Cells 9-end were skipped due to cell commands (structure protection?)
Title #21 was added (8 cell(s), 0:11:24)
Title #24 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #27 was added (1 cell(s), 0:02:05)
Title #28 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 was added (1 cell(s), 0:02:21)
Title #30 was added (1 cell(s), 0:02:30)
Title #31 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50/2 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #52 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #53 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/1 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/2 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/3 has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/4 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/5 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/6 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/7 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/8 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/9 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/10 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/11 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/12 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/13 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/14 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/15 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/16 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/17 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/18 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/19 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/20 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/21 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/22 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/23 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/24 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/25 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/26 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/27 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/28 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/29 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/30 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/31 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/32 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/33 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/34 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/35 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/36 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/37 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/38 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/39 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/40 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/41 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/42 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/43 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/44 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/45 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/46 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/47 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/48 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/49 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/50 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/51 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/52 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/53 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/54 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/55 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/56 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/57 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/58 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/59 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/60 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/61 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/62 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/63 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/64 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/65 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/66 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/67 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/68 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/69 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/70 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/71 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/72 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/73 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/74 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/75 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/76 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/77 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/78 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/79 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54/80 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
wbwoodford
Re: Phineas and Ferb: The Daze of Summer (Main title doesn't
Post by wbwoodford »
I am having the same problem with 2 Phineas and Ferb DVD has anyone figured this out?
For some disks, you can use the Manual Open DVD method explained at /manualdvd/ . Unfortunately, you have to know a bit about the structure of the disk to give the right string...
The topic you're replying to is several years old. Did you get any error messages during the loading of the disk? You could be chasing a completely different problem.
