Convert LPCM->FLAC, leave DTS-HD MA & TrueHD untouched
paulster
#1 Post by paulster » Mon Oct 01, 2012 8:34 pm
I haven't played with custom conversion profiles yet as I really haven't had the need to, but now that MakeMKV can handle 24-bit FLAC conversion I'm wondering whether it's possible to set it to convert only LCPM tracks to FLAC, but to leave any DTS-HD (HRA or MA) and TrueHD tracks in their native format.
Since I extract more than one audio language from my discs generally I don't want everything ended up getting converted to FLAC.
Romansh
Re: Convert LPCM->FLAC, leave DTS-HD MA & TrueHD untouched
#2 Post by Romansh » Mon Oct 01, 2012 10:33 pm
MakeMKV.app/Contents/Resources/flac.mmcp.xml
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name - Default -->
    <name lang="eng">FLAC</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang),+sel:lossless,-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track as is</description>
        <description lang="ger">Track 1:1 kopieren</description>
    </outputSettings>
    <outputSettings name="lpcm" outputFormat="LPCM-raw">
        <description lang="eng">Save as raw LPCM</description>
        <description lang="ger">Als RAW LPCM speichern</description>
    </outputSettings>
    <outputSettings name="wavex" outputFormat="LPCM-wavex">
        <description lang="eng">Save as LPCM in WAV container</description>
        <description lang="ger">Als LPCM im WAV-Container speichern</description>
    </outputSettings>
    <outputSettings name="flac-best" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (best compression)</description>
        <description lang="ger">Als FLAC speichern (h?chste Komprimierungsstufe)</description>
        <extraArgs>-compression_level 12</extraArgs>
    </outputSettings>
    <outputSettings name="flac-fast" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (fast compression)</description>
        <extraArgs>-compression_level 5</extraArgs>
    </outputSettings>
    <!-- Default rule - copy as is -->
    <trackSettings input="default">
        <output outputSettingsName="copy"
                defaultSelection="$app_DefaultSelectionString">
        </output>
    </trackSettings>
    <!-- Save LPCM mono or stereo as FLAC -->
    <trackSettings input="LPCM-stereo">
        <output outputSettingsName="flac-fast"
        </output>
    </trackSettings>
    <!-- Save multi-channel LPCM as FLAC -->
    <trackSettings input="LPCM-multi">
                defaultSelection="$app_DefaultSelectionString,+sel:true">
        </output>
    </trackSettings>
    <!-- Save TRUEHD as FLAC -->
    <trackSettings input="TRUEHD-stereo">
        </output>
    </trackSettings>
    <trackSettings input="TRUEHD-multi">
        </output>
    </trackSettings>
    <!-- Save DTS-HD as FLAC -->
    <trackSettings input="DTSHDMA-stereo">
        </output>
    </trackSettings>
    <trackSettings input="DTSHDMA-multi">
        </output>
    </trackSettings>
    <!-- Save DTS-HD LBR (low quality) as FLAC (just to decode) -->
    <trackSettings input="DTSHDLBR-stereo">
        </output>
    </trackSettings>
    <trackSettings input="DTSHDLBR-multi">
        </output>
    </trackSettings>
</profile>
Change the TrueHD and DTS-HD rules from outputSettingsName="flac-fast" to outputSettingsName="copy" or simply remove them (in which case the input="default" rule applies).
paulster
#3 Post by paulster » Mon Oct 01, 2012 10:48 pm
Thanks. I'll have a look at that later.
paulster
#4 Post by paulster » Tue Oct 02, 2012 6:13 am
That worked perfectly. I just added a third profile for LPCM->FLAC that left TrueHD and DTS-HD alone so I could use either of the standard profiles or my own.
Works great!
