American Horror Story
TigerMoth
#1 Post by TigerMoth » Sat Sep 29, 2012 3:21 pm
I love this program. Easily worth the $50 for Blu Ray functionality. I'm having difficulty backing-up American Horror Story, however, and was wondering if anybody else is having any luck with it.
Thanks in advance for your time/consideration
setarip_old
Re: American Horror Story
#2 Post by setarip_old » Sun Sep 30, 2012 11:29 am
Hi!
Please be specific - What is the nature of your problem?
TigerMoth
#3 Post by TigerMoth » Sun Sep 30, 2012 2:42 pm
The latest batch of SVQ files seems to have solved it. (prior to this morning, I would get the error message: "Disk Failed To Load."
Thanks for the reply, though, and I apologize for the initial lack of info.
TigerMoth
#4 Post by TigerMoth » Sun Sep 30, 2012 4:02 pm
I guess I spoke too soon. Although disc 1 now processes correctly, disc 2 gives me the same error code that disc 1 used to give:
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/Tom/.MakeMKV/dump_American_Horror_Story__Season_1_Disc_2_DF72F641588092E3.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
If this is simply a matter of being patient while the encryption is cracked, I can certainly wait. I just wanted to make sure that the problem had been reported. I tried to email the dump file but it's too big, I'm afraid.
This is the standard retail North American version.
setarip_old
#5 Post by setarip_old » Sun Sep 30, 2012 4:21 pm
TigerMoth
#6 Post by TigerMoth » Sun Sep 30, 2012 7:55 pm
Yes, I went to that link, also. Here is what it said:
Starting from version 1.5.8 MakeMKV downloads all required SVQ files automatically - all discs that require disc-specific SVQ should work without any additional steps.
setarip_old
#7 Post by setarip_old » Mon Oct 01, 2012 1:05 am
If I'm not mistaken (and that's always a possibility), the program can only automatically upload the SVQs if you have your MakeMKV settings to allow this...
TigerMoth
#8 Post by TigerMoth » Mon Oct 01, 2012 1:22 am
I have the checkbox selected to allow the program to contact the web server for updates. Additionally, it appears that these updates are coming through as the number of SVQ files loading has changed over the last several days. Lastly, Disc 1, which previously failed to load, loaded this morning so I really think it's working.
Apparently, I need to be patient while I wait for an SVQ file for this particular disc. I will also look for a way to email large files so I can send the necessary dump file(s).
My apologies for not including all relevant information in my initial (and even subsequent) emails. I will not waste anybody's time again with the same oversight.
Thank you for taking the time to help me solve this.
setarip_old
#9 Post by setarip_old » Mon Oct 01, 2012 1:49 am
Glad to hear that your problem appears to have been resolved ;>}
spankurmama
#10 Post by spankurmama » Mon Oct 01, 2012 4:01 pm
Still problem with disc 2, disc 1 worked fine after files downloaded and updated
TigerMoth
#11 Post by TigerMoth » Mon Oct 01, 2012 5:05 pm
I sent the dump files for discs 2 and 3 in through a 3rd party transfer site (too big to email). Hopefully they arrived, and will be helpful.
spankurmama
#12 Post by spankurmama » Thu Oct 04, 2012 4:40 pm
Working now, all discs, THANKS!!!!
