New Bond releases not backing up
apxmusic
Re: New Bond releases not backing up
#16 Post by apxmusic » Sat Sep 29, 2012 2:34 pm
I just ordered the Box Set from Amazon.com in the states and I am having the same problems for A View To A Kill - Quantum Of Solace. The earlier movies ripped just fine up to Octopussy, but after that... no luck.
anton-sa
#17 Post by anton-sa » Sat Sep 29, 2012 4:42 pm
mbta3247 wrote:New SVQ files were released today (if you watch the log when MakeMKV is trying to open a disc, the number of downloaded SVQ files has gone from 113 to 116). The Spy Who Loved Me and Goldeneye can now be opened, and I assume most of the other troublesome discs as well.
hmm this is odd.
i run makemkv v1.7.7 on linux (x64) and
here is a clip from my screen:
" MakeMKV v1.7.7 linux(x64-release) started
Opening files on harddrive at /home/data01/blu/000-new-james-bond-blu-rays/THE_SPY_WHO_LOVED_ME
Downloading latest SVQ(s) to /home/anton/.MakeMKV ...
Loaded 93 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
so it appears i only get 93 svq's. i however have tried to delete all *.svq and then re-download... still only 93..
jayper
#18 Post by jayper » Sat Sep 29, 2012 6:02 pm
hmm this is odd.
Running MMKV 1.7.7 on Win 64-bit. It only downloaded 93 SVQ files as well. I am backing up my new copy of Goldeneye now. Will report back.
jayper
#19 Post by jayper » Sat Sep 29, 2012 6:23 pm
jayper wrote:
hmm this is odd.
Reporting back. Everything worked perfectly!
ajoberstar
#20 Post by ajoberstar » Sat Sep 29, 2012 6:43 pm
jayper wrote:
jayper wrote: Reporting back. Everything worked perfectly!
Do all of your discs work now, or did you just test Goldeneye?
I'm still showing 116 SVQs and cannot decrypt A View To Kill. Haven't tried The Living Daylights, Tomorrow Never Dies, or Casino Royale again, which are the only others I still haven't been able to decrypt.
anton-sa
#21 Post by anton-sa » Sat Sep 29, 2012 8:26 pm
still no joy here
im still using the folders i backed up onto my harddrive though. when i got my boxset i took the 9 discs and did a full backup in makemkv onto harddrive.
with the idea id create the mkv file from here. still no luck though...
spankurmama
#22 Post by spankurmama » Sun Sep 30, 2012 2:17 am
I was not receiving all svq files so I was still not able to rip. I repeatedly closed the program and reopened. Every time I did this the number of svq files would increase, until The Spy Who Loved Me worked. I'm still not showing all 113 svq files as Mike mentioned in the earlier post. This has worked for me and I've been trying to rip all of these since Tues.
anton-sa
#23 Post by anton-sa » Sun Sep 30, 2012 11:42 am
Ok guys, heres an update.
I went from receiving 93 SVQ's to 102SVQ's...
out of the 9 titles im trying to decrypt of which none would decrypt, i now have 3 titles working
namely,
YOU ONLY LIVE TWICE
GOLDENEYE
ON HER MAJESTYS SECRET SERVICE
keep in mind the other 13 titles i have not tried as i bought them on seperates and they have been backed up long time ago.
ajoberstar
#24 Post by ajoberstar » Sun Sep 30, 2012 9:40 pm
I'm currently at 125 SVQ files. I was able open A View To Kill, so things are looking good. I'll check back in after I try the rest.
syztemlord
#25 Post by syztemlord » Sun Sep 30, 2012 10:27 pm
Everything has ripped fine except Casino Royale, getting this error:
The source file '/BDMV/STREAM/00882.m2ts' is corrupt or invalid at offset 34925856768, attempting to work around
The source file '/BDMV/STREAM/00882.m2ts' is corrupt or invalid at offset 34948048896, attempting to work around
The source file '/BDMV/STREAM/00882.m2ts' is corrupt or invalid at offset 34948116480, attempting to work around
ajoberstar
#26 Post by ajoberstar » Mon Oct 01, 2012 1:00 am
I've ripped all 22 movies now.
syztemlord wrote:Everything has ripped fine except Casino Royale, getting this error:
Is there any damage on your disc?
syztemlord
#27 Post by syztemlord » Mon Oct 01, 2012 7:18 am
ajoberstar wrote: Is there any damage on your disc?
It looks fine, I'll try playing it in the PS3 tonight. Are there any programs that check for disc errors?
Romansh
#28 Post by Romansh » Mon Oct 01, 2012 11:43 am
syztemlord wrote:Are there any programs that check for disc errors?
http://www.makemkv.com/faq/item/4
Hash check errors indicate read errors not related to copy protection.
syztemlord
#29 Post by syztemlord » Mon Oct 01, 2012 12:25 pm
That's great, thanks!
jayper
#30 Post by jayper » Mon Oct 01, 2012 11:51 pm
I have only tested Goldeneye at this point.
