The Dread AACS error
medelle
#1 Post by medelle » Sun Sep 23, 2012 3:18 am
For the last three or four versions of MakeMKV, I've been getting this error. I've searched the forums and tried all the various solutions I could find to no avail.
Anyone got any new ideas?
FWIW, I'm trying to rip Doctor Who A Christmas Carol.
Gadgetman!
Re: The Dread AACS error
#2 Post by Gadgetman! » Sun Sep 23, 2012 12:38 pm
Are you using a DVD-drive with the same Zone as the DVD?
You may have run into a protection version not seen on too many other DVDs, in which case you're supposed to send a log to the MakeMKV creators.
http://www.makemkv.com/faq/item/8/catid/6
Mac Mini, 2005 with superdrive, 2GB RAM, 80GB SSD, Core2Duo 2.16GHz CPU...
2 x LG USB DVD-drives and 'old spiteful' an IDE-based DVD-reader from a desktop connected to the internals of an old FW-HDD.
Writes Sci-fi:
http://www.planetfurry.com/~anthony/
medelle
#3 Post by medelle » Fri Sep 28, 2012 11:24 pm
My DVDs are indeed the same region as the drive and I'm running into this issue on every single disc I try.
I've sent numerous reports to the creators of MKV but the issue has not been fixed. I've tried downgrading and got all the way back to I
think it was version 1.4, with no success.
Oddly enough, using Make MKV on Windows under VM Fusion trying to rip the exact same discs works. Still, I would like to not have to go onto
the Windows side of my computer every time.
Anyone have any thoughts?
#4 Post by Woodstock » Sat Sep 29, 2012 6:49 pm
The fact that it works under Windows in a VM would make me think it's a problem with OSX... Did you recently update the machine? The new version "knows" about Bluray, so it might be enforcing things that Windows still lets you bypass.
medelle
#5 Post by medelle » Sun Oct 28, 2012 3:08 am
The last update I applied to the machine was OS 10.8.2. As I recall, I was having the issue before I applied the update, but I confess I'm not
100% on that.
