New Bond releases not backing up
I am having problems trying to back up the new release on the Bond 50 boxset and Casino Royale. All previously released discs back up fine but the following discs give an SSQ download failed error:
For Your eyes Only
On Her Majesty's Secret Service
Casino Royale
Octopussy
Dianonds Are Forever
a View To a kill
The living daylights
Goldeneye
Tomorrow never dies
Any suggestions please? using v1.7.7 for Win 64.
For Your eyes Only
Casino Royale
Octopussy
a View To a kill
Goldeneye
Tomorrow never dies
spankurmama
Re: New Bond releases not backing up
add you only live twice to that for me
These are the ones I'm having trouble with:
The Spy Who Loved Me
Octopussy
A View to a Kill
The Living Daylights
Goldeneye
Tomorrow Never Dies
Casino Royale
MakeMKV is able to at least open the other discs so I can choose which titles to copy (I've only actually copied 2 so far). I tried using Pavtube Blu-Ray Ripper on one of the discs listed above, but it was also unable to properly decrypt it.
Looks like they rolled out a new BD+ code, which we have to wait for someone to crack.
(previous edit removed after further testing revealed problem was with Quicktime)
Octopussy
A View to a Kill
Goldeneye
Tomorrow Never Dies
Casino Royale
LessThanJake
I've had success with the following of these titles from the Box Set Region A (USA)
Diamonds Are Forever
You Only Live Twice
I am using MakeMKV v1.7.71 [darwin(x86-release)] On a Mac.
You Only Live Twice
ajoberstar
Everything from Dr. No through The Man With The Golden Gun worked for me so far. Ran into an issue with The Spy Who Loved Me and I sent the SVQ dump into MakeMKV support.
Has anyone sent in the SVQ dumps for the other discs they've had issues with?
LessThanJake
I'll be doing this as I work my way through the set.ajoberstar wrote:Everything from Dr. No through The Man With The Golden Gun worked for me so far. Ran into an issue with The Spy Who Loved Me and I sent the SVQ dump into MakeMKV support.
I sent the dump for Goldeneye in.
Hi All
I have the blu ray collection, region 2/region B. i believe this is from UK.
none of the discs so far will decrypt. im using makemkv 1.7.7 linux.
im only copying the 9 previously unreleased titles, as i have already bought the others prior as seperates.
so far not copying is:
diamons are foever
on her majestys secret service
the spy who loved me
you only live twice
im trying to email dump files but they are large. 19mb. cant seem to send.
any other ways to get them to support@makemkv.com ?
ftp ?
regards
diamons are foever
you only live twice
ftp ?
regards
hi
ive sent a few dumps in.
hope the admin doesnt think he is being mailbox flooded.. each dump is 19meg
I bought the new Bond 50 Bluray collection in the UK, I've attempted to rip all 22 discs to put on my Apple TV but the following "failed to open disc":-
* A View To A Kill
* The Living Daylights
* Tomorrow Never Dies
All the others ripped fine, if it helps I can send the logs in I'm using 1.7.7 on an iMac, what exactly do they need from me? Is there anything else I can try??
Many Thanks
* A View To A Kill
Many Thanks
ajoberstar
In another thread, I had seen someone mention they put the dump in their public Dropbox folder and emailed the link in.anton-sa wrote: im trying to email dump files but they are large. 19mb. cant seem to send.
ajoberstar
I'm using Windows, but I would guess it's similar. There should be a folder path in the log that tells where the dump was created. That dump should be all the information needed.mateytate wrote: All the others ripped fine, if it helps I can send the logs in I'm using 1.7.7 on an iMac, what exactly do they need from me? Is there anything else I can try??
Hi
just thought id report back, the other james bond discs i havent bothered copying as i already have these (bought seperates)
so i wanted the 9 discs that were previously unreleased, none of them backup though.. well the backup onto the drive but they dont
decrypt.
a view to a kill
diamonds are forever
goldeneye
octopussy
oh her majestys secret service
the living daylights
tomorrow never dies
you only live twice
i really hope a solution gets found
decrypt.
a view to a kill
goldeneye
octopussy
tomorrow never dies
you only live twice
ajoberstar
These ones all work for me now:anton-sa wrote:Hi
decrypt.
a view to a kill
goldeneye
octopussy
tomorrow never dies
you only live twice
- Diamonds Are Forever
Goldeneye
Octopussy
- A View To Kill
Tomorrow Never Dies
New SVQ files were released today (if you watch the log when MakeMKV is trying to open a disc, the number of downloaded SVQ files has gone from 113 to 116). The Spy Who Loved Me and Goldeneye can now be opened, and I assume most of the other troublesome discs as well.
