For reference, this is on an MBPr running 10.8.2.
MakeMKV v1.7.71 darwin(x86-release) started?
Optical drive "BD-RE ASUS BW-12D1S-U 1.20" opened in DASPI v1.3 mode.?
Using direct disc access mode?
Downloading latest SVQ(s) to /Users/username/.MakeMKV ...?
Loaded 93 SVQ file(s)?
Processing BD+ code, please be patient - this may take up to few minutes?
Processing BD+ code using generic SVQ from builtin/00000.svq?
BD+ code processed, got 1 FUT(s) for 1 clip(s)?
File 00008.mpls was added as title #0?
Title #00001.mpls has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
File 00851.mpls was added as title #1?
Title 00006.mpls is equal to title 00008.mpls and was skipped?
Title #00405.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title 00800.mpls is equal to title 00851.mpls and was skipped?
Title 00009.mpls is equal to title 00008.mpls and was skipped?
File 00003.mpls was added as title #2?
Title 00850.mpls is equal to title 00851.mpls and was skipped?
Title 00007.mpls is equal to title 00008.mpls and was skipped?
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title 00801.mpls is equal to title 00851.mpls and was skipped?
Title #00003.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title #00002.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
File 00005.m2ts was added as title #3?
File 00006.m2ts was added as title #4?
Title #00012.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Title #00008.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped?
Operation successfully completed?
Saving 3 titles into directory /Users/username/Desktop/Snow Flower and the Secret Fan?
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '12908888064'?
Failed to save title 1 to file /Users/username/Desktop/Snow Flower and the Secret Fan/Snow_Flower_And_The_Secret_Fan_t01.mkv?
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'?
Failed to save title 2 to file /Users/username/Desktop/Snow Flower and the Secret Fan/Snow_Flower_And_The_Secret_Fan_t02.mkv?
1 titles saved, 2 failed
