The Avengers Assemble - Crashes MKV
Twowit2woo
#1 Post by Twowit2woo » Mon Sep 24, 2012 8:44 am
MakeMKV v1.7.7 win(x86-release) started
IFO file for VTS #20 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #3 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #4 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #13 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #14 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #15 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #16 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #17 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #18 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #19 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #20 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #21 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #22 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #23 was added (47 cell(s), 2:16:41)
Title #24 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #25 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #26 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #27 declared length is 2:16:41 while its real length is 1:07:48 - assuming fake title
Title #31 was added (2 cell(s), 0:06:13)
Title #46 was added (2 cell(s), 0:06:13)
Title #47 was added (2 cell(s), 0:06:13)
Title #48 was added (2 cell(s), 0:06:13)
Title #49 was added (2 cell(s), 0:06:13)
Title #93 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #94 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 17 is equal to title 1 and was skipped
Title 3 in VTS 17 is equal to title 1 and was skipped
Title 4 in VTS 17 is equal to title 1 and was skipped
Title 5 in VTS 17 is equal to title 1 and was skipped
Then it pauses, then brings up a dialogue box "MakeMKV BETA popup"
Fatal error occurred, program will now exit.
Click on OK and MakeMKV disappears, but curiously it leaves behind makemkv.exe process and makemkvcon.exe. The former is taking up 50% CPU usage and slowly consuming Mem usage. have watched it increase from around 50MB to (currently) 150MB.
Have killed both but could do with some further help!
Twowit2woo
Re: The Avengers Assemble - Crashes MKV
#2 Post by Twowit2woo » Mon Sep 24, 2012 12:43 pm
UPDATE:
So I thought I'd start creating log files. Turned on the setting, closed MakeMKV, restarted it and ran it through.
Went through without crashing!
Turned log files off, repeat ... works absolutely fine! (I'd previously tried it 3 times including a reboot)
The only thing that changed was removing and reinserting the disc.
Odd - but solved :)
setarip_old
RESOLVED: Re: The Avengers Assemble - Crashes MKV
#3 Post by setarip_old » Tue Sep 25, 2012 7:21 pm
Hi!
You may have solved your problem by having unwittingly dislodged a dust bunny or some crud from the lens of your reader/burner ;>}
