Problem converting my ISOs.
Sarvajanik
Post by Sarvajanik »
Hi guys,
As a movie buff who travels a lot, I carry around my collection my hard drives instead of my original BDs itself - primarily in the fear i'll scratch the hell out of them otherwise. I used to store all my DVDs and BDs as ISOs... but now, I've commenced condensing my library; and since I have the BDs anyways, have decided to chuck the extras et al and carry only the main movies along.
I've converted a good number of my ISOs to MKVs with great ease - thank you MakeMKV devs!. But have stumbled upon a few errors recently.
I have my 'Superman Anthology' collection - the 8 BDs in ISO, but am unable to convert them to MKVs. It'll be some time before I can get back home to my original discs, so haven't had the chance to try that.
Here's the error I get:
Debug log started at Mon Sep 24 06:16:39 2012 , written by MakeMKV v1.7.71 darwin(x86-release)
001005:0000 MakeMKV v1.7.71 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Sarvajanik/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL PIONEER DVD-RW  DVR-112D BC14" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-ROM hp DVDWBD TS-LB23L 0600" opened in DASPI v1.3 mode.
003006:0000 Opening files on harddrive at /Volumes/Drive 4/Supe/Encodes/MainMovie/S1
003305:0000 AACS directory not present, assuming unencrypted disc
005050:0000 Evaluation version, 10 day(s) out of 30 remaining
003307:0000 File 00000.mpls was added as title #0
005014:0000 Saving 1 titles into directory /Volumes/Drive 4/Supe/Encodes
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
001003:0020 DEBUG: Code 0 at +]FO&P98h`}S}~fVC<&:121262647
001003:0020 DEBUG: Code 0 at dhH)J44#,B\KeU&I37T=#:29397955
005003:0000 Failed to save title 0 to file /Volumes/Drive 4/Supe/Encodes/Superman_The_Movie_(1978)_t00.mkv
005004:0080 0 titles saved, 1 failed
Any help would be appreciated.
FYI...
- I'm on a MacPro, using the latest version of MakeMKV.
- The drive I'm creating my Library on is a WD Caviar Green - which I know isn't the fastest - but it's what is recommended for my Dune.
- I've tried creating the MKV on another HD, but the same error.
- The ISO plays perfectly fine all through - without a single error.
Best
-SD
Smithcraft
Re: Problem converting my ISOs.
Post by Smithcraft »
The only time I get this error is when I try and make one drive do too much. The heads can only be in one place at a time, so making them be here, there, and over there, in a short time can cause an issue.
So, just make sure you aren't doing too much with your destination drive, and I would be willing to guess that this problem should go away.
And just incase, maybe the drive is very fragmented, you could try defragging it to see if that helps keep the heads from traveling too much.
SC
Sarvajanik
Thanks for the reply SC,
I don't think that could be an issue. I converted a few more of my ISOs to MKVs with success onto the same drive. And since I'm on a Mac... am not too sure if there is any native way to defrag a drive - as OS X handles all data dumps 'smartly'.
The strange part is... that the ISO plays perfectly. So I don't think there could be something wrong. I re-tried the extract with the supplements... and they ripped just fine. So could it be that something went wrong with my main title when I created the ISOs?
-SD
Smithcraft
Maybe Activity Monitor can show you what is using the disc?
I'm not sure if OS X will keep all drives defragged or only the boot drive.
Otherwise, anything is possible when you did the original rips.
SC
