DTS Lossless and 3/2+1
Skyman1
#1 Post by Skyman1 » Mon Sep 24, 2012 10:23 am
Hello everybody...
during my encoding there are different options...
one of that is the possibility to select the audio option:
DTS LOSSLESS
DTS 3/2+1
I note that I can select also one one this whitout problem... but I want to one which is the different between this 2 mode... and which is the better audio resolution, or if need to select both.
Thank you
Romansh
Re: DTS Lossless and 3/2+1
#2 Post by Romansh » Mon Sep 24, 2012 1:37 pm
DTS 3/2+1 is the core (regular DTS, lossy) of the DTS-HD Master Audio track (lossless).
DTS Lossless is the full track, including both the core (required to decode the whole thing), and the extensions (lossy -> lossless difference, and sometimes additional channels or increased samplerate).
