Hallo,
while using makemkv 1.7.7 win (x86) the conversion of Three Musketeers 3d blue ray stops after 5 to 7% completion with the message:"Copy complete. 0 titles saves, 1 failed" (Status screen: Failed to save title 8 to file....)
No different while using the option mpeg4 or mpeg-mvc-3d.
This is my first try to convert an 3D blue ray.
Any idea what?s wrong ?
Thanks in advance
Converting Three Musketeers 3D stops (rel 1.7.7)
- Contact:
Re: Converting Three Musketeers 3D stops (rel 1.7.7)
Please enable debug logging per http://www.makemkv.com/faq/item/8 and post the log here, or just send all required files per same instructions.
Attached you will find the logfile. My Windows Explorer (XP SP2) can?t see any file information on the blue ray disc. So I am not able to send additional files. Any idea to solve this ?
- MakeMKV_log.txt
- (13.54 KiB) Downloaded 1041 times
