Great News - The PROBLEM is RESOLVED....
1. I un-installed Divx (crap)
2. I re-created my mkv file (from mkv video only + DTS Eng Audio Track)
But as I did so I was monitoring the mkvmerge process with my window-7 Resource Monitor,
and guess what....
After mmg.exe finished (click ok) the physical writing of the new mkv output file had not finished !!!!
So I WAITED for another 2 mins for all writes (buffer writing out as monitored by Windows Resource Monitor) to the output file to COMPLETELY FINISH BEFORE I accessed the new mkv file.
3. IT WORKS! - no more problems or memory leak.
MakeMKV makes bad MKV files?
Chetwood
Re: MakeMKV makes bad MKV files?
How about asking the creator of MKVToolnix?bcw-123 wrote:Will mkvmerge (mmg.exe) be fixed...soon...?
Icanseestars
I've noticed 1.7.7 generating files that Handbrake has problems with converting.
On a few Blu-ray's I've ripped the file at one point cant be read by Handbrake via it's error log, however the original file plays fine with no apparent errors. A remux with mkvmerge solves the problem and the video can be converted with Handbrake just fine.
Mkvmerge does log that something is wrong during the remux
Dont know who's at fault here.Warning: A block group was found at position 2607356411, but no block element was found inside it. This might make mkvmerge crash.
