BUG REPORT: 1.7.7
larsenguitars
BUG REPORT: 1.7.7
Post by larsenguitars »
I don't know where to report bugs, so here goes;
1.7.7 will not run under fresh install Debian Wheezy [amd64]
makemkvcon expects libcrypto version 0.9.8 (Debian Wheezy currently has version 1.0.0)
ldd /usr/bin/makemkvcon
shows;
libcrypto.so.0.9.8 => not found
So then I tried creaiting a symlink as a workaround;
sudo ln -s /usr/lib/x86_64-linux-gnu/libcrypto.so**.1.0.0** /usr/lib/libcrypto.so.0.9.8
and just to be sure, I also did a symlink for libssl;
sudo ln -s /usr/lib/x86_64-linux-gnu/libssl.so**.1.0.0** /usr/lib/libssl.so.0.9.8
Now, ldd /usr/bin/makemkvcon
shows;
/usr/lib/libcrypto.so.0.9.8: version `OPENSSL_0.9.8' not found (required by /usr/lib/libmakemkv.so.1)
I'm still trying to complete the workaround, but at this stage, it seems this is something that needs to be fixed for v1.7.8
EDIT: Workaround completed.
I didn't want to resort to this:
I temporarily enabled the repository for squeeze & installed the libssl0.9.8 package.
Works fine now.
Still, this should be fixed for v1.7.8 so it will be able to recognize libssl1.0.0
Re: BUG REPORT: 1.7.7
Post by mike admin »
makemkvcon has no dependency on libcrypto. It only depends on libmakemkv which is open-source and that you're supposed to build yourself on your box. Check dependencies of libmakemkv and recompile it if necessary.
