How do you turn on embedded subtitles?
KRArmstrong
I have a registered version of MakeMKV version 1.7.6 for Mac. I want to have subtitles embedded and everyone talks about turning that on but I can not find it in the preferences.
Re: How do you turn on embedded subtitles?
MakeMKV will normally rip the subtitle tracks and put them into the MKV file automatically.
If you're asking about rendering them onto the video track, that would require something like Handbrake.
Chetwood
Luckily MakeMKV sets regular subs to off by default. Open the mkv in MKVmerge's header editor and set the default flag to yes (which can still be ignored by your player).
KRArmstrong
I was trying to use handbrake but it will not read the subtitles. Handbrakes doc says that mkvs need embedded subtitle track or I need the subtitles in some other file format. I do not see where MakeMKV allows me to embed the subtitles or make another subtitle file. Is my only recourse to use a third party program that is not officially for the mac? Or is there a way within makeMKV?
Release version of HB (0.9.7, I think) or one of the nightly builds?
The release version doesn't know about PGS subtitles from Bluray disks. The nightly build version can read PGS subtitles from either an MKV or a MakeMKV BD backup directory, and burn them into the video (when outputting MP4 files) or include the tracks themselves (MKV files).
Chetwood
"Jonathan Buschmann provides a universal (32/64bits) package for Leopard/Snow Leopard for MKVToolNix. You can download the latest version (5.7.0 build 2012-07-11-cd22) directly from my site."KRArmstrong wrote:Is my only recourse to use a third party program that is not officially for the mac?
Sounds official enough to me.
