tjsuominen
#1
Post
by tjsuominen » Mon Sep 17, 2012 5:32 am
Edit - Changet Gb -> Mb/sec.
Hi!
I know for sure
that there was / is an article here over MakeMKV forums on enhancing the copy transfer speed over lan/wlan to NAS drive (currently my speed is only 1.5 - 2 Mb/sec) on Windows but I can not find the tip (burried within some discussion chain...) anymore. And yes, I have tried :/
Any hints?
Thx.
//timo
Olivier
#2
Post
by Olivier » Fri Sep 28, 2012 8:39 am
tjsuominen wrote:Edit - Changet Gb -> Mb/sec.
Hi!
I know for sure
Any hints?
Thx.
//timo
Strange, without any specific tuning on both MakeMKV or my NAS I got the maximum possible output (capped by my BluRay drive). So I got from 23Mb/sec to 35Mb/sec.
I'm on a old Mac and the NAS is a Synology but everything is linked in Ethernet Gigabyte.
Gadgetman!
#3
Post
by Gadgetman! » Fri Sep 28, 2012 3:11 pm
Quick question; you're not using WiFi, are you?
If you're on a wired network, you shouldn't have any other limitations than the DVD/BD drive itself.
(Unless you have an ancient PC, of course. Then that may also slow it down a bit)
Mac Mini, 2005 with superdrive, 2GB RAM, 80GB SSD, Core2Duo 2.16GHz CPU...
2 x LG USB DVD-drives and 'old spiteful' an IDE-based DVD-reader from a desktop connected to the internals of an old FW-HDD.
Writes Sci-fi:
http://www.planetfurry.com/~anthony/
